I've uppgraded from a BV-4 42" gnr 7 HD ready to a BV-9 full HD gnr 9 plasma. My problem is that the screen is dark grey when it should be black. The BV-4 was much closer to all black, actually my BV-6 LCD is better. The picture settings are at neutural, and setting the brightness down doesn't help. Any thoughts on this problem will be appreciated :-)
See hear feel B&O.
check what you saftwaer is.I had the same problem with older softwaer.
menu-option(not depress only mark)-red-go
My dealer uppgraded the Beosystem 3 to the latest software version, it says: BV 4 plasma sw 1.05 and h8 sw 10.02a.
i have the same sw, and my tv is bv9 MRK 3 with d10 panel,and I have no problems whatsoever with this SW.
contact the dealer and tell about your problem
Does anybody know if there is a separate adjustment for the plasma panel? I remember my dealer calibrated my BV-4 panel with a panasonic remote.
