        1st March February 2012
	    Latest post 10-18-2011 7:47 AM by  stefan. 16 replies.
								        03-18-2011 6:03 PM
									        BelgianEnth
								                - Joined on 03-18-2011
								                - Posts 9
										    Hello,
For the moment I have a BeoVision 7-40 with Beolab 7 speaker in a study room (Room1)
I would like to expand my system as following:
- Room2 : BeoSound 9000 with 2 x BeoLab 6002
- Room3: BeoSound 5, BeoMaster 5 and 2 x BeoLab 5
- Room4: BeoVision 10-40" with 2 x BeoLab 4
- Room5: BeoLab 3500
- Room6: BeoVision 7-55 with BeoLab 7-6
My questions are:
- Will I be able to listen to the harddrive of the BeoSound 5 in all the rooms ?
- Will it be possible to listen to a CD played from te BeoSound 9000 in all the rooms ?
- Do I need extra speakers in Room4 or can I play the BeoSound9000-radio/CD also with the Beovion's integrated speakers ?
- If I run ML-cable to all components, together with UTP for futher use, a BeoLink network can be made ?
Thanks for your help !
									        MurphyBrooks
								                - Joined on 07-30-2009
								                - Posts 9
										    Re: Expand existing system
										    You can listen to hard drive and net radio off BeoSound 5 in all rooms and listen to 9000 CD/radio in all rooms. You don't "need" the 4's - BS5 or 9000 can send source through integrated speaker in BV10. You should run Cat 7 wire to all sources, and fit with ML/PL baluns so to "future proof" your network.
									        stefan
								                - Joined on 04-16-2007
								                - 200 miles from Struer
								                - Posts 1,733
										    The problem in your configuration are the two audiomasters. If you connect Beolabs to your BS9000 and to BS5, you have to set them up both as audiomasters. I `d recommend a music room (Room 3) with BS9000 connected digitally and Powerlink to BL5 and BS5 masterlinked to BS9000.
- Room 1: BeoVision 7-40 with Beolab 7 video link room V.OPT 6 access to all video- and audio sources
 - Room2 : Beolink active with 2 x BeoLab 6002/BL11 audio link room L.OPT 6 access to all video- and audio sources
- Room3: BS9000, BS 5, BM 5 and 2 x BL 5 audio main room A.OPT 2 (BS5 set to NO AUDIOMASTER) access to all video- and audio sources
- Room4: BeoVision 10-40" video link room V.OPT 6 access to all video- and audio sources (you can listen to audio sources via BV10 speakers)
- Room5: BeoLab 3500 audio link room L.OPT 6 access to all video- and audio sources
- Room6: BeoVision 7-55 with BeoLab 7-6 video main room V.OPT 2 access to all video- and audio sources
- Should work
- Nice set up
BTW In this setup with three new TVs I would consider a HDMI matrix for video distribution...
Stefan
									        BelgianEnth
								                - Posts 9
										    Thanks for your answer.
In practice, how easy will the system be to operate. How can I control the cd-player or the beosound 5 in room4 for example with a Beo4 ?
To be honest, I prefer not to have videolinks. Is there any way to have control of both BeoSound 9000 and BeoSound 5 in each room without videolink ?
What happens if 2 audiomasters are on 1 system ?
Or can I solve it by using an B&O Active in Room3 for use with the BeoLab5 and just use the BeoSound5 as a slave and thus not using the volume control wheel ?
									        stefan
								                - Posts 1,733
 "In practice, how easy will the system be to operate. How can I control the cd-player or the beosound 5 in room4 for example with a Beo4 ?"
Just press CD, BS9000 will be activated, BV10 will start up in audio mode (speakers on, screen off), additional Beolabs will start up.
"To be honest, I prefer not to have videolinks. Is there any way to have control of both BeoSound 9000 and BeoSound 5 in each room without videolink ?"
So don`t use it. You save an RF link amplifier, cable, or an HDMI matrix.... And yes, sure, you can control all your audio sources in all link rooms.
"What happens if 2 audiomasters are on 1 system ?"
Two audiomasters in one masterlink system will be controlled simultaneously. You can set Your BS9000 (or BS5) up to A.OPT5 or 6, which means, this device is a local source and can only be accessed directly in that link room, whre it is installed.
"Or can I solve it by using an B&O Active in Room3 for use with the BeoLab5 and just use the BeoSound5 as a slave and thus not using the volume control wheel ?"
Not quite sure, but might work. So you control BS5 via BL active with Beo4, and maybe it`s possible to select music via BS5 wheel...(?)
The sad thing is, you can`t use the digital inputs of your BL5s.
Stefan
									        BelgianEnth
								                - Posts 9
										      stefan:
Ok, that's what I want.
So I need a B&O Active for the BeoLab5. How do I cable my setup ? Just ML and UTP to the units and PL to the speakers ?
And you suggest to make 1 room with the BeoSound 9000 and Beosound 5 ?
									        BelgianEnth
								                - Posts 9
										    and optical spdif together with PL from BS9000 to BL5
Only problem is I think it will not be easy to find spdif cable on reel.
									        BelgianEnth
								                - Posts 9
										    I think i'm confused with SPDIF, thinking this is Toslink.
Am I right that the digital connection on both the beosound 9000 and a beolab 5 is an RCA-plug ? In that case normale digital cable can be used. I just run 1 cable from the BS9000 to one BL5 and then also from the left to the right BL5.
Things are getting more clear day by day
									        stefan
								                - Posts 1,733
										      BelgianEnth:
  stefan:
If you are using a BL active you connect your Beolabs to Powerlink of the active. You control all your sources via BL active.
If you are "creating" a musicroom with BS900, BS5 and BL5 you masterlink the 9000 and BS5 and connect BL5 to Powerlink and spdif to your BS9000. That`s what I would do...
Stefan
									        stefan
								                - Posts 1,733
										      BelgianEnth:
Yes, digital connection BS9000 > BL5 have rca plugs. You can daisy chain bothe BL5s.
Stefan
									        BelgianEnth
								                - Posts 9
Stefan
after reading this very interesting forum for a weekend that's also my conclusion.
BUT, I have the following problems:
- Beosound 5 control is to be placed next to a Beovsion 7, this is next to the room where I will place the Beolab 5.
- all the rooms are somewhat in 1 very large open space with little walls between. I think I will have problems with the control and will have to use the IR-range reducers as used in the B&O stores.
Therefore, I'm planning:
Room 1 : Beovision 7-40 with Beolab 7 and BeoMaster 5 - BeoSound 5
Room 2 : Beolink Active with 2 x BeoLab 6000
Room 3 : BeoSound 9000 digital and Powerlinked with BeoLab 5 (but I will not buy the BeoLab's this year, so firstly no speakers connected to the BS9000)
Room 4 : BeoVision 10-40"
Room 5 : BeoLab 35000
Room 6 : BeoVision 7 or 8 with left and right speakers
Will all rooms have access to all the sources and control them ?
Control-problem is : Rooms 1, 2, 3 and 4 are in 1 large room with little walls. For example, the Beovision 10-40" is also visible in room 2. To solve this I will place the IR-eye of the Beolink active in a corner, out of sight of the Beovision 10-40.
Or is there an other solution ?
Thanks for all your help
									        stefan
								                - Posts 1,733
"- Beosound 5 control is to be placed next to a Beovsion 7, this is next to the room where I will place the Beolab 5."
BS5 is connected via three cables to BM5: USB - DVI - Power. I have 12m to BM5 and everything is working fine.
"- all the rooms are somewhat in 1 very large open space with little
have to use the IR-range reducers as used in the B&O stores."
I wouldn`t use  IR range reducers. You can "modify" the IR reception of your units. For example I painted the IR glass of my BL2000 (on the backside!) black, so now the IR reception is reduced. You can also reduce IR range of Beo5/6 and the newer Beo4 (1710). You can also set zones (BV10-40?) to V.OPT 4, which means, that BV won`t rect to TV, CD...commands, but to LINK-TV, LINK-CD commands. Just press LINK before selecting mode (TV, CD...)
"Therefore, I'm planning:
 the BS9000)
Will all rooms have access to all the sources and control them ?"
Great setup. Yes, should work. Problem is Room 3: You won`t hear anything....this year...:) ">![]()
maybe A8 help...? And be aware, that BS9000 switches automatically to A.OPT 0, when no PL speakers are connected. So, you can`t control anything from this room (this year) unless you connect a "dummy" Powerlink plug. Now you can change the option to A.OPT 1 or 2
"Control-problem is : Rooms 1, 2, 3 and 4 are in 1 large room with
corner, out of sight of the Beovision 10-40."
See my comment above...but to my experience, placing IR eyes in a corner or hidden walls helps.
"Or is there an other solution ?"
The problem with Beo is, that there are a lot of options, especially when you have all that stuff you want to buy.....
Should work. Maybe you want to post a drawing of your rooms, that shows your planned installation?
Stefan
									        BelgianEnth
								                - Posts 9
										    ok, I've finally decided what equipment I will use. The Beovision 7-40 and a Beovision 10-40 will be in a separate room, not linked because of no use and not possible for wiring.
Other linked rooms:
room1 : Beovision 10-32
room2 : Beosound 9000 with Beolab 9
room3 : BeoActive with Beolab 6002
room4 : Beolab 3500
Could you help me for setting up the ideal options ?
Tnx
									        BelgianEnth
								                - Posts 9
										    I've made a drawing of the rooms
									        stefan
								                - Posts 1,733
										    BV7-40 V.OPT1
BV10-40 V.OPT 1
BV10-32 V.OPT 6 (2)
BS9000 A.OPT 1 (2)
BL active L.OPT 5 (6)
BL3500 L.OPT 5 (6)
I recommend to integrate BV7-40 as a videomaster in V.OPT 2. This will make it possible to access audio sources in TV lounge and in your BV10-40 room, if masterlinked and set to V.OPT 6.
In your setup it is important, that All IR receivers cannot see each other.
Hope this helps.
Stefan
									        BelgianEnth
								                - Posts 9
										    Thanks for your help.
I've made the drawing more accurate. The Beosound 9000 is in sight of the BV7-40 remote control, therefore i'm thinking of using a B&O Active for the BL9-speakers. Is there another solution ?
For the 6002 speakers, what would you recommend for easy operating ? Is it possible to control this room by pointing the remote to the BV10-32 or is the active IR-eye necessary ?
I think because of the place of the BS9000 it is adviseable not to use the speaker outputs of the BS9000 and disable his IR, or am I wrong ?
regards,
									        stefan
								                - Posts 1,733
										      BelgianEnth:
You`r welcome.
  BelgianEnth:
Yes. I thought about that solution too. But if your BS9000 is A.OPT 1 )audio only - for RADIO, CD, N.MUSIC...) and your BV7 V.OPT 1 (video only - for TV, DTV, DVD, V.MEM...) it should work. That`s why I suggested these options. Option 1 only respond to its "own" commands: Beovisions respond to video commands and not to audio sources, Beosounds vice versa.
BS9000 with A.OPT 0 adding a BL active with IR eye and L.OPT 5 would be an alternative solution.
  BelgianEnth:
Yes it is possible to control the dining area via BV10-32 with V.OPT 2 or 6, but I recommend an additional BL active for this 6002 area, because I see it as an extra zone, and it is possible to listen to BS9000 in the dining area and watch TV in the kitchen. I think it is easier to place the IR eye for reliable operation too. BTW if you are using the new Beo4 navi (1710) or Beo5/6 it is possible to reduce the IR range in the remote control.
It is also possible to reduce IR reception in your BS and BVs. I did that with my BL2000 in the kitchen. My BL2000 responded to IR commands from the living room, So I reduced the reception by gluing a small tape to the IR eye in the BL2000. It can`t be seen from outside.
It is also possible to use L.OPT 4 for the dining room. You have to add LINK to your Beo4. Press LIST - now LINK will be displayed - and then CD, RADIO...Now you can control the selected source as usual and no other zones will be affected.
Hope this helps.
Stefan
        Page 1 of 1 (17 items)
