For music only, the BM7000 is damned good, but connecting Sony TV on it (via toslink optical converter + din to RCA)+ iphone + TV decodeur + DVD + PC ... the selector AUX, tape1 tape2, does not support it anymore and seems at the end . I'm loosing signal between TV and BM7000, it sounds really bad a bit like in a bathroom.
I tried multiple connections types, everything on TV then TV on BM7000, everything directly on BM7000, same result. exemple : TV is connected to AUX, if I select Tape1 or tape 2, it also works .... strange.
I will keep it for another room for jazz-whisky evenings..
If you have any idea that can help me keeping it, they are welcom.
thanks forall answers
Eric
