Latest post 03-18-2011 9:31 PM by Søren Mexico. 4 replies.
Page 1 of 1 (5 items)
  • 03-17-2011 3:56 AM
    Beovox RL 35, membranmateriale
    Hej har forsøgt at Google om basserne er med Gummi eller skum materiale..uden resultat
    Andet info modtages med glæde bestykning m.m.
    Vh
    FarMargren
  • 03-17-2011 8:19 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beovox RL 35, membranmateriale
    Velkommen til Beoworld !
    Basenhederne har gummikanter og de holder fint.
    Delefiltrene har en skidt tendens til at udvikle dårlige forbindelser men at gå lodningerne igennem er forholdsvis hurtigt gjort.
    Lidt mere info kan findes her : http://www.beoworld.org/prod_details.asp?pid=655
    og her : http://beocentral.com/beovoxrl35
  • 03-17-2011 2:34 PM In reply to
    Martin, mange tak for velkomst og svar.
    Kan man med fordel skifte man så kondensatorerne ved samme lejlighed, ved
    lodning/check ?
    Vh
    FarMargren
  • 03-17-2011 2:49 PM In reply to
    • Dillen
    • Posts 5,008
    Ja, det ville give god mening.
    Det er kun nogle få komponenter men der findes alligevel et kit til det.
  • 03-18-2011 9:31 PM In reply to
    Martins kits are lifesavers for B&O equipment, get them and try one speaker first to hear the difference, I hope that RL 35s are not your only B&O pieces, tell us a little more about it, and go to your profile and tell us which part of the world you occupie, then its easier for us to give "lokal" advise and help.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
