1st March February 2012
Latest post 03-30-2011 2:11 PM by KMA. 4 replies.
03-13-2011 7:54 AM
deepseamaster
- Joined on 04-24-2009
- Posts 8
Beosund 8 - Popping noise
I have an iPhone plugged into a beosound 8 and this morning it started making random popping noises when music plays. Not all the time, but enough to be both noticable and irritating.
Has anyone else seen this/have any thoughts on it?
KMA
- Joined on 08-13-2007
- Posts 101
Re: Beosund 8 - Popping noise
Did you upgrade to iOS 4.3 on your iPhone?
I did, and the popping noises started to happen, irregularly but very often on all tracks. No such problem with Beosound 8 before the upgrade to iOS 4.3 on my iPhone 4.
Strangely, my iPad upgraded to the new iOS 4.3 did not have the same problem with Beosound 8. I upgraded both iPhone and iPad right away when the 4.3 came out.
What solved my iPhone 4 & Bousound 8 problem was a "Reset to factory settings" restore on the iPhone. Now the iPhone plays without any problems with audio on Beosound 8. The popping sounds are gone.
I did a search on the matter at Apple's Support Forums, and apparently a similar issue has occurred to some users with earlier iOS updates as well, with iPhone audio docks from various manufacturers. So the issue is not isolated to iPhone & Beosound 8.
Do a restore on your iPhone and see if it helps. In my case it did -- although a restore has not helped with all of the reported similar post-upgradre problems with different audio docks.
KMA
Current setup: BeoVision 10-46 (grey speaker cover, AR, motorized stand) with Apple TV 2 (FireCore), Sony BDP-S780, Mac Mini, BeoLab 11 (silver), Beo5, BeoSound 8 (red speaker covers). Accessories: A8 Earphones, wine bottle coasters.
B&O product history, in chronological order since 1990, after the onset of the treaded BeoVirus (I tend to upgrade/change my setup "infrequently"): BeoSystem 2500 (with blue speaker covers), BeoLink 5000, BeoSystem 7000 (complete; silver/black), BeoLink 7000, RedLine 60.2, BeoVox Penta, BeoVision MX4000 (black, motorized floor stand), BeoCord VX5000 (black), BeoSystem 4500 (complete), BeoCenter 9500, BeoLab 8000, BeoLab 6000, BeoVision Avant (original, 28" AR, VHS, green), BeoCenter 2300, BeoVision 3-32 (grey speaker frame, AR, motorised cabinet), DVD1 (grey), BeoCord V8000 (grey), Beo4, BeoSound Ouverture (w/ floor cabinet stand), BeoVision Avant RF (grey, 32", AR, VHS), BeoSound 9000, BeoCenter AV5 (blue), BeoVision 1 (yellow, motorized floor stand), Beo1, BeoSound Century (yellow), BeoCenter 1 (blue, AR, motorized floor stand), BeoSound 1 (silver, floor stand), BeoVision Avant RF DVD (grey, 32", AR), BeoVision 7-32 MkI (AR, motorized floor stand), BeoLab 3 (black), BeoSound 2, BeoVision 10-40 (grey speaker cover, AR, motorized stand).
deepseamaster
- Posts 8
You are spot on, did the update yesterday. Should have guessed the weak link was the iPhone!
Will see if this fixes the problem.
Thanks,
Matt
deepseamaster
- Posts 8
the issue is back with vengance... is anyone else suffering from this?
KMA
- Posts 101
Amusingly enough, it's been reported that with iOS 4.3.1, which was out last Friday, March 25th, audio "pops" and "clicks" occur again with some Audio Docks w/ iPhones. It appears that there is no consistency in this, i.e. someone with a certain Audio Dock experience it, while others with the same dock do not.
I haven't updated to 4.3.1 yet, did you perhaps?
Again, a "Reset to Factory Settings" on your iPhone might help.
If the iOS update is once again the reason for this, this is getting "not-so-funny" -- extra trouble after each update.
I hope you get the problem solved. It would be good to know if the iOS update is the culprit.
KMA
Page 1 of 1 (5 items)
