1st March February 2012
Latest post 03-14-2011 6:03 PM by Blackrix. 15 replies.
03-12-2011 11:56 AM
harrykym
- Joined on 08-04-2008
- Rossendale
- Posts 86
Ouverture with Beolab 2500 wont work!! HELP!
Hi Beoworld hope all you guys are well.
I've just bought an Ouverture with Beolab 2500 but when I've got it home and set up I cant get the thing to work!!
The red light is on,
the doors open,
the cd clamp opens and close but wont spin or play CDs,
No radio or tape functions at all
The display wont turn on apart from the red light
If you press cd, tape, radio or aux the door just close
If I use my Beo4 nothing happens apart from the red light flashes once
Its almost in a standby mode or something anybody got any ideas?
Is there a reset button?
BS-3, BS-1, BS-OVERTURE, AVANT-28"RF, AVANT-28" DVD, AVANT 32" RF, 3xBEO-4, LC-1, 4xBEOCOM-6000, BEOCOM-2, A9 KEYRING, DVD1, Beosystem 10, BEOCOM 3, BEOLAB 2500, BEOSOUND CENTURY, BEOLIT 707
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
Re: Ouverture with Beolab 2500 wont work!! HELP!
probably an option problem, you will have toreset it bl1000
press standbyand sound together
then press 1
then press storeshould work then I had a similar problem
if it doesn't the try above with either 0 or 2 one of which will work
sorry cannot remember the correct option mode but it is one of the above
!salut
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
harrykym
- Rossendale
- Posts 86
Hi thanks for the reply,
do i do this using the beo4 or on the Ouverture because i dont have any buttons saying standby or sound?
stotty1111
- Posts 924
Haaaaaa!!!!!!!!!
Don't know how to do it with a beo4 but yes its remote base
try pressing list until optin appears press go scroll thro to audio press go press0 1 or 2then go - i think thats it otherwise do a search on the site for option setting
I always use my bl 1000 as its dead simple!
t
now found my book, it goes
hold standby buttonwhilst pressing list, scvroll to options press go
press list until a optthen hkey 1
should then be fine
t
harrykym
- Rossendale
- Posts 86
Cant get that to work!! any other options?
stotty1111
- Posts 924
hold standby button whilst pressing list - ie at same time - , scvroll to options press go
press list until a opt then key 1
try pressing go
should then be fine
sorry about the mistakes etc my keyboard is on it way out and i cannot get a qwerty kybd in france they us ethe quaint old azerty`layout
t
harrykym
- Rossendale
- Posts 86
HI thanks for the help but it doesn't work! it must be another problem with the thing!!
mediabobny
- Joined on 04-19-2007
- Greenwich Village, NYC
- Posts 336
harrykym:
Wouldn't hurt to unplug it and leave it unplugged for several hours.
harrykym
- Rossendale
- Posts 86
According to the chap I bought it from, the Ouverture as been in storage for the last 2 years and not used. Could this be the problem? ie damp?
harrykym
- Rossendale
- Posts 86
Blackrix:
No matter in what option the BeoSound Ouverture is programmed, it should always work using the keyboard on the Ouverture itself. Sometimes a key on the keyboard gets stuck between the surrounding metal on the keyboard, keeping the key pressed. But in that case the doors also will not close, because when a key is pushed the Ouverture won't close the doors to protect the fingers of the user. It could also be a problem in the Ouverture.
pressed all the buttons to check for sticking all seem OK, should i take the front panel off and check the connections?
Peter
- Joined on 02-12-2007
- Posts 9,572
Was it sold as working? Did you see it work when you picked it up? I suggest that maybe that was why it was in storage?
harrykym
- Rossendale
- Posts 86
Peter :
Hi Peter, it was sold as seen, he did tell me that it was working fine upto going into storage but when he brought it out, it wouldn't play anything. I was hoping it was a simple fix but as I only paid £200 (including the Beolabs) its a worthwhile punt!! I've turned it off now to see if that will help... Anyone got any other ideas?? Do the control panels go faulty?
harrykym
- Rossendale
- Posts 86
I have to say Beoworld I'm a bit disapointed with the poor response to my post, there was a time when answers or solutions where 10 a penny!! Is there a new site no ones telling about?
Blackrix
- Joined on 04-20-2009
- Posts 975
harrykym:
I think you got the right answers in a very short time, but sometimes there just is not a ready to go answer. It seems like the problem is in your Ouverture, but it could be the keyboard, the processor, the power-supply or maybe something else. It could be that the Ouverture was struck by lightning, who knows?
You could try to disconnect the keyboard from the display PCB and see if it will work on remote. Make sure the Ouverture is in option 1, not option 0, or else the remote won't work.
Page 1 of 1 (16 items)
