I picked up a used Beogram 8002 recently and only get a fairly loud hum as output from the turntable.  I suspect the cable is at fault, but thought I'd check here before I try buying a new cable.
The turntable is known to be working, because I tested it out before purchasing it.  It was hooked up to a B&O receiver.  I bought this cable on ebay and when I have it hooked up, I get hum from the turntable, regardless of whether the turntable is playing anything, or even powered on.
If anyone has any suggestions, please let me know.  Thanks!
