Latest post 03-13-2011 1:43 PM by JC. 9 replies.
Page 1 of 1 (10 items)
  • 03-11-2011 9:54 AM
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Apple TV+SkyHD+XBox 360 connected to BV7-32, HOW?
    Hi all,
      Anyone else done this or is it not possible???
      BeoVision 7-32 MK3 connected to :-
    1 I have the SkyHD going into DVI-I with scart for audio.
    2 XBox 360 into component with red and white for audio.
    3 Apple TV has nowhere to go??? Or is there a solutuion?
     Thanks in advance
    Jonnie
  • 03-11-2011 1:56 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Apple TV SkyHD XBox 360 connected to BV7-32, HOW?
    I have my ATV from composite to scart (decoder) on my 4-42. Works perfectly and also did make ATV learn a remote that was included in my Set Top box. Now it is hidden in the cabinet and controlled by Beo4!
    Best regards
    Spiros
  • 03-11-2011 3:56 PM In reply to
    Re: Apple TV+SkyHD+XBox 360 connected to BV7-32, HOW?
    Hi, The best way is to look for a cheap Gefen HDMI expander on ebay which you can connect to the DVI & control with 1 of the STB controllers connecting up to four HDMI sources.
    Regards Douglas
  • 03-12-2011 4:18 AM In reply to
    I don't think a non-HDMI BV7 will control an HDMI expander.
    It is a possible solution if you want to control it manually.  Though you'll also need something to switch the audio too.
  • 03-13-2011 5:14 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Thanks guys!
    Not looking too promising then?
      Jonnie
  • 03-13-2011 6:36 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Jonnie,
    Give it a try as I wrote. It should work. It does work for me with excellent results!
    Best regards
    Spiros
    Best regards
    Spiros
  • 03-13-2011 7:14 AM In reply to
    Hi, If you have an up to date STB list in your TV & the latest software 30,03 then you can operate a HDMI expander!
    I know because i have it, I dont know if you can be bothered with the hastle & expense wiht this option as B&O must update Chip & Flash software!
    Regards Douglas C
  • 03-13-2011 9:05 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Hi Spiros,
      Maybe I am being a bit stupid Embarrassed
      The only connection on ATV2 is a HDMI socket.
      Kind regards
        Jonnie
  • 03-13-2011 10:05 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Ouppps. Sorry. I was talking about Atv1!!
    Best regards
    Spiros
  • 03-13-2011 1:43 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    No worries, thanks for the inputSmile
      Kind regards
        Jonnie
