Latest post 03-14-2011 6:12 PM by Blackrix. 3 replies.
Page 1 of 1 (4 items)
  • 03-10-2011 7:32 PM
    • justw
    • Not Ranked
    • Joined on 07-11-2008
    • U.S.
    • Posts 15
    Looking to replace S45 woofer, or specs.
    So, I loaned a pair of s45's to a friend and when they came back one of the woofers is frozen. Anyway I am looking to replace it. Since these are no longer made does anyone have a recomendation on a replacement, for both if I have to, or the T&S specs so I can do my own shopping. These are the 6302 vintage.
    ~W
  • 03-12-2011 12:03 PM In reply to
    Re: Looking to replace S45 woofer, or specs.
    Thanks W. I hope your replacements work out.
  • 03-12-2011 1:14 PM In reply to
    • justw
    • Not Ranked
    • U.S.
    • Posts 15
    I'm still looking for and specs anyone has on these woofers.
    The pole piece part of the m agnet structure had come "unglued" and pinched the voice coil. My spare went to another user so now I'm looking to replace mine. Has anyone measured T&S parameters of these for comparison???
    ~W
  • 03-14-2011 6:12 PM In reply to
    You can actually have this problem repaired. I know there is a company in the Netherlands that can fix it for you (Audiolab), and I am almost sure someone in the USA can do the same. It is probably cheaper than have replacement woofers send to you!
