Latest post 03-28-2011 6:45 AM by Heribert. 2 replies.
Page 1 of 1 (3 items)
  • 03-09-2011 5:22 PM
    turn off Mac using Beo5
    I have a MacMini connected to my BV7 via PUC and V.Aux.
    How can I configurate my beo5 to turn off my mac or to send him asleep?
    With the normal apple remote you must push the "play/pause" button for a while and your mac will fall asleep.
    thanks
  • 03-10-2011 9:59 AM In reply to
    Re: turn off Mac using Beo5
    Hi Bolingo
    If you have allready set it up using HDMI and a PUC controller, you should be able to choose connections, the AV socket used, and at some point after choosing the PUC "Apple remote", you should be able to choose some preferences like "Sleep at standby" "Sleep at sourcechange" or something like this. Maybe however this depends on your tv software. I have it working perfectly at home.
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 03-28-2011 6:45 AM In reply to
    press long the "GO" Button to send the Mac asleep. Works with my ATV1+2
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
