Latest post 03-08-2011 12:16 PM by Søren Mexico. 5 replies.
Page 1 of 1 (6 items)
  • 03-07-2011 7:07 PM
    • McRib
    • Not Ranked
    • Joined on 10-01-2009
    • USA
    • Posts 19
    Beogram platter height
    for the modern beograms (eg, beogram 7000, 6500, 4500 etc)
    is the platter supposed to be flush with the deck surface or a bit raised? i've seen pics of both examples. for my 2 cents, it would seem to make sense that it would be raised--
  • 03-07-2011 8:49 PM In reply to
    Re: Beogram platter height
    With pick up arm to center, the platter should be 2.5 to 3.0 Mm over top plate (deck surface)
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-07-2011 10:10 PM In reply to
    • McRib
    • Not Ranked
    • USA
    • Posts 19
    thanks
  • 03-08-2011 3:01 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    If it wasn't, a 12 inch record would scrape on the deck surface and you could hardly grab its edges and lift it off.
  • 03-08-2011 7:30 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I think this is one of the spoiling factors regards the looks of these decks - I appreciate there wasn't really much of an alternative to maintain the tight dimensions (I actually think they could have just about done it by moving the bearing forward though, but I bet either looks or cost was the major factor). They look so much nicer flush!
    Olly.
  • 03-08-2011 12:16 PM In reply to
    Step1:
    I like the BG 5000 platter design, the platter looks level, with border fazed of to deck level, and agree with Step, a bigger platter and different edge design would improve the look
