Latest post 03-14-2011 6:13 PM by Blackrix. 4 replies.
Page 1 of 1 (5 items)
  • 03-07-2011 4:31 PM
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    Beocord 5500 no power
    Hi
    does the beocord 5500 have a main fuse at all? I picked one up which was supposed to be working but it seems completely lifeless. Ive done all the obvious things but there is no life in at all?
    Is it a simple fuse problem or is it dead??
    Andy
  • 03-07-2011 5:26 PM In reply to
    Re: Beocord 5500 no power
    There is a main fuse (near the Power supply, of course). Try to change it -but it will probably blow again...there is a reason why it has blown. I hope somebody here on Beoworld with more technical skills than me, can tell You more about what can possibly cause the problem.
    Steffen
  • 03-09-2011 6:29 AM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Hi
    many thanks for the reply I have changed the fuse and it seems to work well I will wait to see what happens!!
    Andy
  • 03-09-2011 7:22 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I have seen similar cases where the fuse blew for no apparent reason in Beocord 5500s.
    My guess is that the fuse rating has been poorly chosen.
  • 03-14-2011 6:13 PM In reply to
    Or it could just be a bad fuse.
