Latest post 03-03-2011 3:02 AM by SteelRain. 4 replies.
Page 1 of 1 (5 items)
  • 03-02-2011 1:52 PM
    Beo5 Config Tool software installation problem
    I am having problem with the above software, irespective of which version, they are all doing the same thing, so I assume it must be my PC.
    When it installs, it says installed successfully and I open the program, but I am not getting the full page displayed, I only get thje centre section of the page displayed. The option to max and minimise is not shown as its cut off, any ideas please. I am on Windows 7.
    I have uninstalled, reinstalled several times but no different.
    Thanks for any help.
  • 03-02-2011 3:10 PM In reply to
    Re: Beo5 Config Tool software installation problem
    The Problem should Be the Size of your Desktop System Font....
    BeoCT Works only correct with a Desktop System Font Size of 96dpi...
    Try and reply....
  • 03-02-2011 3:13 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    just an idea, maybe you are using 120 DPI instead of 96 DPI in your "Display propertiers"
  • 03-03-2011 2:59 AM In reply to
    Normal 0 false false false EN-GB X-NONE X-NONE MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
  • 03-03-2011 3:02 AM In reply to
    Thanks Niederrheiner & Vienna, same suggestions one solution, thanks guys.
    Big Smile
