Latest post 03-03-2011 9:21 AM by hifi52. 2 replies.
Page 1 of 1 (3 items)
  • 03-01-2011 6:55 AM
    • hifi52
    • Not Ranked
    • Joined on 03-01-2011
    • Posts 2
    beogram cd 3500
    I have a beogram cd 3500 player which has always been wall mounted. It will not track anymore when wall mounted but will work fine on a horizontal plane. this suggests to me that the tracking arm is worn. Is it possible to get replacement components?
    All observations gratefully received.
    Filed under:
  • 03-02-2011 5:16 PM In reply to
    Re: beogram cd 3500
    It's very unlikely to be a mechanical problem.These mechs are very robust.It's probably the laser power is reduced,and the focusing is more crucial when the unit is vertical?I recommend "recapping" the servo board before anything else.Certainly don't try to adjust the servo arm mech.Martin(Dillen) can supply a cap kit for this work.
  • 03-03-2011 9:21 AM In reply to
    • hifi52
    • Not Ranked
    • Posts 2
    Re: beogram cd 3500
    Thank you very much for your advice - I shall follow it up.
    Kind regards,
    Keith
