Latest post 03-02-2011 1:59 PM by ........... 11 replies.
Page 1 of 1 (12 items)
  • 02-28-2011 1:58 PM
    Centre speaker
    Hi, What are you thoughts? I have been offered a pair of beolab 4000's for the right money.  Or I have a beolab 7.4 for nearly similar money!  I have a pair of penta labs for my front speakers?  I am swaying more towards the 7.4, Let me know your thoughts. Cheers Nick
  • 02-28-2011 2:45 PM In reply to
    Re: Centre speaker
    I would get the 7.4.  If you can get it for similar money and you like the looks.  You will prob find some that say to pair the non-ALT speakers with like (e.g., BL4000) but I have BL8000s as front speakers and BL3 for center and it works great.
  • 03-01-2011 1:05 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Centre speaker
    I would imagine the 7.4 would be much more capable of keeping up with your Pentas. It has 2x250w ICEpower amps and ALT! Miles beyond 4000s. But, I am just going off of spec sheets and things I have read on here. I havne't had the oportunity to listen to either - at all.
    Have a listen!
    Evan
  • 03-01-2011 4:59 PM In reply to
    Re: Centre speaker
    I have gone for the 7.4 as its a dedicated speaker, also acoustic lense technology. Hope it works well with the pentas!  I am oicking it up at the weekend
  • 03-01-2011 5:13 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Centre speaker
    Congratulations Nick! I'm sure it will perform wonderfully.
    Evan
  • 03-02-2011 2:48 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Centre speaker
    Nick
    you have a totally unrelated pm
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 03-02-2011 3:32 AM In reply to
    Re: Centre speaker
    The best choice!
    Your set up will sound amazing!
  • 03-02-2011 1:30 PM In reply to
    Re: Centre speaker
    stotty1111:
    Nick
    tony
    Hi Tony dont know how I missed that one! Reply is on its way! Cheers
  • 03-02-2011 1:31 PM In reply to
    Re: Centre speaker
    Llewelyn:
    The best choice!
    Cheers Llewelyn! Do you think it will be better than if I had chosen a 7.1??  Cheers Nick
  • 03-02-2011 1:43 PM In reply to
    Re: Centre speaker
    The 7.1 is a totally different speaker.  It's a stereo speaker, made to be a center speaker for some but not really meant for that.  It makes a great soundbar though, and a decent center.  The 7.4 makes a great center, and a crappy speaker for anything else!  Take your pick!
  • 03-02-2011 1:49 PM In reply to
    Re: Centre speaker
    macjonny1:
    I am looking forward to hearing it!
  • 03-02-2011 1:59 PM In reply to
    Re: Centre speaker
    As long as it's intended use is as a centre, it will be great! 7.1s are great speakers, and more flexible than the 4 but the 7.4 is without question the better dedicated centre.
    The alt works a treat!
    Also, in my humble opinion, it looks much better on the motor floor stand and does a better job of hiding any cables...
    It might be a 'crappy speaker for anything else', but by the same token a Ferrari is a crappy car for shopping... It was designed purely to be an amazing centre and does a great job. I'm sure you'll be impressed Laughing
