Latest post 09-07-2011 2:03 PM by Style. 12 replies.
Page 1 of 1 (13 items)
  • 02-28-2011 11:10 AM
    DVB-T2 support
    Does B&O support DVB-T2 for Beovision 8-40? (Yes I know that the DVB-T standard is supported)
    Filed under: ,
  • 02-28-2011 1:08 PM In reply to
    Re: DVB-T2 support
    No, the current DVB-HD T/C/S2 from B & O, do not supports  T2.
    But B & O are working on a new module with support for T2. !
    BeoVision 4 - 50 HD -  Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
  • 02-28-2011 1:29 PM In reply to
    Re: DVB-T2 support
    Can you please tell me what T2 is? What is the Difference to DVB-T?
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 02-28-2011 1:57 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: DVB-T2 support
    Heribert:
    sorry, article is in German ...
    http://blog.ors.at/stories/start-des-dvb-t2-versuchsbetriebes-der-ors-in-wien/
  • 03-03-2011 2:19 PM In reply to
    Re: DVB-T2 support
    Sweden does also use DVB-T2 for HD channels. B&O confirms that they are working on a solution, but they cannot give a release date.
  • 03-03-2011 2:30 PM In reply to
    Re: DVB-T2 support
    Ditto for Finland. New multiplexes will use DVB-T2 and MPEG4 for both SD and HD channels on them. Currently the only TVs with integrated DVB-T2 receivers are from Sony. Plenty of people who think they just bought a state of the art TV will be disappointed when the terrestrial HD broadcasts begin, and they'll be getting an STB again if they want to receive them...
    In a nutshell, DVB-T2 differs from DVB-T by using improved modulation techniques. For the same frequency constraints (channel usage), this can be used for either much improved bandwith or more robust transmission. Delivering HD channels over plain DVB-T is quite wasteful. The robustness comes in handy in sparsely populated countries like Finland, where getting proper area coverage quickly gets expensive.
    -mika
  • 04-07-2011 1:49 PM In reply to
    Re: DVB-T2 support
    Today Bang & Olufsen has sent a mail to me to tell that DVB-T2 now is supported with the new DVB-HD Mk III module. Smile
  • 08-30-2011 11:39 AM In reply to
    Re: DVB-T2 support
    Problem: Channels that er transmitted in DVB-T2 where CI+ is used to copy protect the signal does not work with the software version 0.1.7.2. B&O will probably solve this in a new software version, but no date is available. This is a problem with some of the HD channels here in Sweden.
    The signal can not be decoded.
  • 08-30-2011 3:24 PM In reply to
    • akoro
    • Top 500 Contributor
    • Joined on 08-07-2008
    • Espoo, Finland
    • Posts 88
    • Gold Member
    Re: DVB-T2 support
    B&O solution is one of the few that has CI and normal conax slot for pay-tv.
    I have tested encrypted CI DVB-T2 signals from TV Viihde (the world championships of track and field) Yle HD channel and it works great and has fantastic picture quality.
  • 08-30-2011 4:01 PM In reply to
    • Style
    • Not Ranked
    • Joined on 08-01-2011
    • Posts 40
    Re: DVB-T2 support
    I have dvb c and ci and it works great
  • 09-07-2011 11:31 AM In reply to
    Re: DVB-T2 support
    To Akora. The CI+ is not linked directly to the to physical slots. CI+ is a standard used under DVB-T2 for copy protection of the signal. So are you sure that the terrestical broadcaster is using CI+ for the channels you are mentioning? If Finland has started to use CI+ encryption it is the a new thing.
    Bang and Olufsen has acknowledged the problem and via the dealer said that a new software version is required and will be released later. Of course with expected release date.
    Samsung had exactly the same problem in Sweden and released an update on the 10th August.
    To Style: For exactly which channel do you know that the CI+ copy protection is used?
  • 09-07-2011 2:01 PM In reply to
    • Style
    • Not Ranked
    • Posts 40
    Re: DVB-T2 support
    I have DVB C from Comhem in Sweden and they use CI on all HD channels.
  • 09-07-2011 2:03 PM In reply to
    • Style
    • Not Ranked
    • Posts 40
    Re: DVB-T2 support
    Btw i bredes to phone Comhem and get the card paired in order to make it work
