Vienna:
Are you using the B&O RF Link Amplifier to distribute the RF-Signal or are you doing this via the modulator
of a VCR?
PS: there are a lot of solder joints / cables / internal sockets & plugs on the tuner module beeing able to
"respond" to "jiggling"
Hi, this is an ususual setup - there is a BS2 as the "main room" source controller and a distribution amp with it's own feeds (CCTV mainly) spliced in. There is no issue at all on non-B&O tv's, a BV7 and 3500 speakers, nor was there an issue with an Avant when I had one. There are three Mx4002's and this "fault" goes with two of them. various link frequencies have been in play over the years and this problem has always been there.
It behaves like a classic "loose connection / dry joint" fault - but - i have had the boards completely out & can't find anything amiss. B&O dealers have allso had both sets back twice years ago now it's getting too annoying.
I would be happy to abandon the RF input (i don't even have an aerial) IF i can just have RF channel changing (CCTV modulators) from a remote DVR feeding the MX via RF but converted to scart at the back of the MX. Will the VCR be controllable through the ML in much the same way as the (remote) DVD player menus are available? I never had a stand alone VCR, just the Avant, so i don't know. i realise i would need to choose AV or whatever the scart is plugged into at the MX so is this a non-starter to expect a remote VCR to be controlled when the MX is displaying input from a local source - the RF to scart convertor.
Can i use 9.5v min applied to scart Pin 8, taken from somewhere in the MX when TV is pressed, to force it into AV? If the MX is forced rather than selected AV i wondered if it would pass the channel up / down selections over the ML - the remote VCR can be left on at all times by not including it as a link product to anything, can't it?
I like the MX's but can't have a local VCR to swap RF channels and want to retain the Beo4 control - is there any other way to save the MX? Sorry if the above is bit messy, to be absolutely clear: THe MX RF is dodgy, Scarts are OK, How can I get RF via the scart and still control a remote device capable of switching RF channels - like a VCR
