Hi all
Just discovered an IR eye I thought was a 'normal' unit is in fact for a BL  - pc2, it is uncabled and i wqas about to sort it!
My question is, can the pc2 be used with 2 x eyes ie thro' a splitter/combiner plug as per stereo earphones and a laptop?
If so, what would be the max cable run?
My idea is to control the pc output from 2 rooms!
salut
tony
									    I always try to operate using/following the KISS principle --  Keep it simple stupid!
