Latest post 08-09-2011 6:14 PM by hri. 11 replies.
Page 1 of 1 (12 items)
  • 02-24-2011 5:29 AM
    • mgpg89
    • Not Ranked
    • Joined on 12-29-2008
    • Posts 5
    Beovision MX6000 - Menu incomplete! (Reset?)
    I recently got our old Beovision MX6000 out of the basement and installed it in the bedroom.
    I also downloaded the manual from the official B&O products archive and I concluded that my system's menu is incomplete:
    The only things showing in the menu are: Program List / Setup  (and when I select 'Setup', it's incomplete as well ... only a few options to configure a Masterlink etc ...)
    Is there anyone who knows how to resolve this? In its current state, I can't alter the Program List, I can't add channels, I can't choose my default position (w/ the motorized stand), etc ...
    Is there maybe a way to reset the entire device?
    Thanks in advance!
  • 02-24-2011 5:51 AM In reply to
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Re: Beovision MX6000 - Menu incomplete! (Reset?)
    I pretty sure MX6000 was delivered with both the Beo4 and the Beolink 1000 (remote controls), and the software was different...
    Sounds to me like you have read the manual for the Beo4 version, and have a Beolink 1000 version... With the Beo4 version you select channels etc. trough menues, while with the Beolink 1000 you use the remote. Try pressing ">>" does it search after TV channels?
  • 02-24-2011 6:24 AM In reply to
    • mgpg89
    • Not Ranked
    • Posts 5
    Oh, I'm sorry, forgot to mention I have the Beo4 version.
    Pressing >> does not search after TV channels ...
  • 02-24-2011 6:54 AM In reply to
    • mhw
    • Norway
    • Posts 207
    • Gold Member
    Ah, then I'm out of ideas!
    But I'm sure someone much smarter will be along shortly! Good luck!
  • 02-24-2011 4:42 PM In reply to
    I had the same thing a while back!  I never got to the bottom of it as I ended up selling the set, I wonder if you have ended up with my old set??
  • 02-25-2011 3:49 AM In reply to
    • mgpg89
    • Not Ranked
    • Posts 5
    Hahahah, yes, could be ... if you sold the set in the late 90's :p
  • 02-25-2011 4:30 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    The description of your scren menu tells it's an early 90's MX 6000.
    Using a BeoLink 1000 you start tuning by pressing "GOTO"
    using a very old Beo4 you'll find "GOTO" as a "LIST" command and will have to "ADD" it to your "LIST"
    using a newer Beo4 you'll find "V.SETUP" as a "LIST" command and will have to "ADD" it to your "LIST"
    "LIST" >till > "V.SETUP" then "GO"  = Beo4 Display shows "TUNE"  then "GO" and the sreen menu should
    appear ...
  • 08-09-2011 5:34 AM In reply to
    • hri
    • Not Ranked
    • Joined on 08-09-2011
    • Vienna
    • Posts 13
    I just got a 1996 MS 6000.. controlled by BeoLink1000.. everything works fine - program tuning, sound and picture changes storing etc..
    PROBLEM is i cannot access MENU by pressing the menu button to the remote.. so i cannot change the sockets and some other features I'm familiar with..
    i also have second BeoLink1000 - its also not working with it, so its not the remote..
    I found some guys from Denmark have the same problem.. unfortunately i still have no answer from them..
    i would be grateful for some solutions..
    thanks
  • 08-09-2011 8:34 AM In reply to
    • Vienna
    • Posts 712
    ... there have been 5 different versions of the MS 6000 - the 4 digit "TYPE NUMBER" or the Serial #
    would be helpful ...
  • 08-09-2011 10:03 AM In reply to
    • hri
    • Not Ranked
    • Vienna
    • Posts 13
    the TYPE is 78/73..
    thanks..
  • 08-09-2011 1:53 PM In reply to
    • Vienna
    • Posts 712
    This model has only one SCART input which can be accessed via "V.TAPE"
    - therefore no "MENU" is needed/available
    - to access/deactivate S-Video press "SHIFT" + "9"
    PS:
    - for sound adjustments press (repeatedly) "SOUND" , change the parameter(s) and store
    the new setting(s) by pressing "STORE" , "STORE"
    - for picture adjustments press (repeatedly) "PICTURE" , ...
  • 08-09-2011 6:14 PM In reply to
    • hri
    • Not Ranked
    • Vienna
    • Posts 13
    GREAT!! thanks Vienna..
