Hello out there
My lovely beosound 3000 have started doing trouble...
When i try to load a cd, the clamp goes down, and opens a few seconds after. The cd does not spin. Sometimes it turns ~1mm.
Sometimes it suddenly reads the cd, and plays... it can play for like half an hour, but then suddenly stop...
I have just buyed the service manual.
http://dl.dropbox.com/u/2862390/Beosound%203000%20service%20manual.pdf
My plan is to check the laser current by measuring the voltage on 80R3121 according to page 62.
Afterwards turn it into service mode and check for errors.
Right now, im a bit confused, wether its the spindle motor, or a focus error.
I have tried with success to change the laser on a beosound overture, but the cd mechanism was the older cd pro, wich only deny to spin up if it failed to focus. But my beosound 3000 just opens the clamp ?
Thanks in advance!
