Latest post 02-27-2011 5:09 PM by joostdeclercq. 1 replies.
Page 1 of 1 (2 items)
  • 02-21-2011 6:17 AM
    • js
    • Top 500 Contributor
    • Joined on 09-07-2007
    • Brussels
    • Posts 208
    • Silver Member
    Issue with Airport Express to Dac Magic to B&O?
    I read a review in Stereophile which highlights the following issue: as the AE doesn't have a local clock circuit, when the incoming data is interrupted, as it is when you change songs in iTunes, there is no longer a digital output to feed the DAC, which loses lock as a result. Not all DACs deal gracefully with the lost lock and are quick to unmute when the new song is sent to the AE thus the first seconds of a song might be cut off.
    I intend to use a Cambridge Dac Magic with an Airport Express: do you know whether this DAC deals with this issue?
    Thanks, js
  • 02-27-2011 5:09 PM In reply to
    Re: Issue with Airport Express to Dac Magic to B&O?
    Hello,
    I don't exactly know the issue, you describe, but I use an AE successfull with the Dac Magic.  I use the digital output of the AE.
    Kind regards
    Joost
