Latest post 02-21-2011 8:05 AM by Step1. 4 replies.
Page 1 of 1 (5 items)
  • 02-21-2011 12:03 AM
    BEOCENTER 9000 CD PART NEEDED-- CD SPINDLE--
    Hi All,
     I have a Beocenter 9000. The spindle is missing on the CD motor platter. Does anybody know were I might be able to purchase this part????
       Don
  • 02-21-2011 5:11 AM In reply to
    Re: BEOCENTER 9000 CD PART NEEDED-- CD SPINDLE--
    Unfortunately this part is unavailable and is the death of many Beocentres. Youwill either have to find a complete cd unit or use it as a radio-ipod amp.
  • 02-21-2011 5:15 AM In reply to
    I'm pretty sure some time recently somebody claimed to have found a way to remanufacture these, but can't remember whether it ever materialized in any way. Perhaps you'll find the thread by searching the forum (there's A LOT on this subject).
    The original spare part sometimes (very rarely) appears on fleaBay, so you might just try your luck and hang on.
    -mika
  • 02-21-2011 6:28 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    tournedos:
    HERE'S that thread
    If you think nobody cares, try missing a couple of payments.
  • 02-21-2011 8:05 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Is there no reason you can't aquire a magnetic cap from another player and manually clamp the cd? Not elegant but it would save the thing until a spare comes up!
    Olly.
