Latest post 02-21-2011 6:03 AM by Spiros. 11 replies.
Page 1 of 1 (12 items)
  • 02-20-2011 4:37 PM
    Not often seen
    Check this. Not often seen!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 02-20-2011 4:49 PM In reply to
    Re: Not often seen
    And expensive!! From what I understand, these are not the most reliable - I would have a Beo6 in preference any day. The reason for wanting one is to use in a dark room - and the Beo6 is just that much more versatile as you can program the screen for whatever you want and it is properly lit.
  • 02-20-2011 5:01 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Not often seen
    This was if I remember correct custom made. It was also mentioned quite a long ago in Beoworld as well. Project from a member or an ex-member.
    Best regards
    Spiros
  • 02-20-2011 5:38 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Not often seen
    Spiros:
    No Spiros, it's a genuine B&O version. When they came out the were over £400. Where as a standard Beo4 was £160 iirc.
    CraigSmile
  • 02-20-2011 6:41 PM In reply to
    Re: Not often seen
    Genuine B&O, and rare because they were only ever offered to Beoliving customers. I think they came out around the same time as the Beo5 (or perhaps just after), and were offered as an alternative to one.
    They have a "cinema" button in the top button section for Beoliving.
  • 02-20-2011 7:44 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Re: Not often seen
    This honestly didn't know! But I'm sure there was also a member that made a back light screen (at least then) quite a few years back, probably in the old forum.
    Is this version currently available?
    Best regards
    Spiros
  • 02-21-2011 3:13 AM In reply to
    Re: Not often seen
    I remember somebody demonstrating a DIY Beo4 display backlight on the forum quite recently.
    -mika
  • 02-21-2011 3:22 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Re: Not often seen
    Ok!!! Thanks, I'm not crazy nor I suffer from Alzheimer!!
    Best regards
    Spiros
  • 02-21-2011 4:53 AM In reply to
    Re: Not often seen
    Spiros:
    Spiros, In my closetWhistle
  • 02-21-2011 5:44 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Re: Not often seen
    I know, I know. This magic closet has anything a real collector wants!!!!!! I have to come over there someday!!!! BTW. Is there anything you don't have? I think this is the right question in this case!!!!!!!
    Best regards
    Spiros
  • 02-21-2011 5:59 AM In reply to
    Re: Not often seen
    Just kidding Spiros, in case you think I have one! Wish I had...
  • 02-21-2011 6:03 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Re: Not often seen
    Are you sure?!?!!? don't tell me a year later..........ouppssss, I had one!!
    Best regards
    Spiros
