Latest post 05-02-2011 9:30 AM by Leslie. 46 replies.
Page 1 of 2 (47 items) 1 2 Next >
  • 02-20-2011 8:50 AM
    Beolink 7000 recap?
    Can anyone please recommend someone who can do (and knows) a capacitor renewal on my immaculate Beolink 7000?
    The machine is in the London area and I don't really want to send abroad.
    Any help appreciated.
    BF7
  • 03-01-2011 8:19 AM In reply to
    Re: Beolink 7000 recap?
    9 days and no replies? Surely someone (other than Smarties) has the answer?
  • 03-01-2011 8:35 AM In reply to
    Might be worth contacting Tim @ Beocentral?
    What makes you think it needs recapping?
  • 03-01-2011 9:43 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I seem to remember Die_Bogener did a couple of these.
    Do a search in the fora.
  • 03-01-2011 11:23 AM In reply to
    The job is a bit of a pain in the butt, that's one reason why people are keeping their heads down.
    Member nobby (Neil Briffett) does repairs so suggest that you contact him by PM. He is in Farnham so not a million miles from you.
    Regards Graham
  • 03-15-2011 5:17 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    If not mistaken, Leslie had a thorough/detailed post on this subject. From what I had the chance to see although it's a time consuming procedure is not a very difficult one.
    Best regards
    Spiros
  • 03-17-2011 3:12 PM In reply to
    You have to be very careful with the flatcables and the display. And you have to use special smallsized capacitors, otherwise it will not work.
  • 03-19-2011 10:03 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I personall would not touch it unless absolutely nescesary.
    Olly.
  • 03-19-2011 11:58 AM In reply to
    Step1:
    You need some skills to do the job!
    Check this on my Picasa webalbum. Use the slideshow option! Already did 4 now and I succeed on all 4 BL7000's.
    BTW, Link will be blocked after a week. You can download pictures if you're interested, free of chargeSmile
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 03-19-2011 12:53 PM In reply to
    I would replace all capacitors in BeoLink 7000. In most cases the other capacitors are also leaking and it is just a matter of time until you have to open the BeoLink 7000 again.
  • 03-19-2011 1:22 PM In reply to
    Leslie:
    It sure would be useful to know the component values as well Whistle
    -mika
  • 03-19-2011 2:01 PM In reply to
    tournedos:
    Leslie:
    Don't let me open this thing againIck!
    Check picture below from previous BL7000's I've "repaired"
  • 03-19-2011 2:12 PM In reply to
    Laughing Thanks. I hate first opening stuff and then having to go shopping.
    -mika
  • 03-19-2011 2:16 PM In reply to
    Pfff, was afraid for your next question, polarity....Whistle
  • 03-20-2011 7:24 AM In reply to
    Many thanks for the responses. It does need doing as we are now just one way!!!
    Leslie, those photographs are very enlightening and may be of help. I have a friend who is quite good with electrics and has sourced the caps so I am trying to persuade him to have a go at it but it is an immaculate 7000 so I am somewhat worried what I will end up with. You wouldn't want to have a go at it for a reasonable cost would you?
  • 03-20-2011 11:14 AM In reply to
    I would do it for free (except for the shipping costs), but no guarantees. I think your friend can do it, it's not that hard. Let me know...
  • 03-20-2011 11:36 AM In reply to
    OK I see you are in The Netherlands? I am in Sweden but the unit is in London. I will be there this week and will ask my friend how confident he is and maybe we will take the back off together and get a feel for how difficult it may be. If he feels it may be too much can I come back to you? Any shipping costs of course is no problem.
    Many thanks.
  • 03-20-2011 12:10 PM In reply to
    Off course you can! Remember that I can only try to fix the "No Contact" issue.
  • 03-20-2011 2:39 PM In reply to
    The picture text is wrong. Please read what's printed on the caps.
    The real value for the 2 caps is not 22uf, it is  0,22uF. The "." is difficult to read but it is there... Whistle
    The black or blue bar is minus for polarity.
    And there are some more caps to do. There is another one on the backside of the display and on the keyboard.
    It also makes sense to replace or to check the 3.3V lithium cell on the cpu board. They are sometimes leaking.
  • 03-20-2011 3:16 PM In reply to
    Die_Bogener:
    Are you sure Die Bogener? Don't wanna argue with you as an expert but in other threads like this and the other they mentioned 22uF?
    And mine worked with the 22uF caps which I have ordered?? Or am I totally mistaken.....
     I can see a dot if I look closely so it must be .22uF but I'm sure I have ordered the 22uF and put them insteadHmm
    Anyone else who can confirm? I can change the text value on the first posted pictureEmbarrassed
  • 03-20-2011 7:53 PM In reply to
    How much is this value 226?
    It still works perfect.... Check my other thread
    Or this
  • 03-21-2011 2:52 AM In reply to
    I used 22 microfarads as well. Worked ok for me.
    I used ordinary miniature electrolytics rather than smd types.
    Regards Graham
  • 03-21-2011 9:09 AM In reply to
    Leslie:
    22 * 10^6 pF = 22 uF
    Anyway, seems I might just as well roll a dice for my shopping list if I want to be done within one evening Laughing
    -mika
  • 03-21-2011 9:20 AM In reply to
    tournedos:
    Leslie:
    Big Smile
    Anyway, .22uF is the same as 220nF? I think this size does not fit in the SMD housing as shown in the picture, is it?
    So, I can leave the value as it is (on the picture)?
  • 03-21-2011 10:02 AM In reply to
    Leslie:
    220 nF = 1/100 the capacitance of 22 uF...
    The physical size will have as much to do with the voltage rating as the capacitance. Those original SMD cans in the pictures will be good for either 0.22 uF / 63 V or 22 uF / 6.3V - hard to tell from the pictures where a decimal point is and where one isn't...
    If they really are 220 nF, I don't understand why electrolytics were chosen to begin with. There might still be a reason.
    Leslie:
    I've never seen the originals myself (yet), so my answer is a definite maybe.
    -mika
