jahur:
sorry to bump this thread, but i have a beogram9500, when i go to play any vinyl format the said vinyl plays slow then speeds up to normal speed and stays there.
i was advised by a dealer that i should just let the turntable warm up with the vinyl on the platter spinning at any speed before actually moving the arm into stage.
he told me that the slow start could be to do with under use or dry bearings caused by under use and was best to let it spin for 5 mins and for it to warm up. it does work from time to time. i have just left the problem as its not the end of the world for me.
this might help it may not.
Fit a new drive belt. You can't really tell anything until you do this.
I have sold very many B&O tangential decks and I have never known one to need "warming up". Suggest that is dealer bullsh1t.
Order part number 2732062 from another B&O dealer or contact member "Dillen" who can also supply.
