Latest post 02-18-2011 6:17 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 02-18-2011 12:34 AM
    Beomaster 3000-2 and Philips GA-212 Turntable
    Hello,
    I need some technical advise.  I just acquired a nice Beomaster 3000-2.  I have an existing Philips GA 212 turntable that I would like to use with this.  When testing this I barely have any levels (volume at 8 out of 10 before a peep).  Someone told me that these are designed for Bang and Olufsen turntables and that I would need a power amp for the turntable.  Not quite sure what is meant by that.  Should this not work?  Is there something so unique with these receivers that requires a "special" turntable?
    Thanks!
    Filed under: ,
  • 02-18-2011 12:47 AM In reply to
    Re: Beomaster 3000-2 and Philips GA-212 Turntable
    You will need a phono preamplifier Sounds Heavenly, can help you
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 02-18-2011 1:20 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    The Beomaster 3000 has two Phono inputs. One has a built-in RIAA preamplifier (the other hasn't).
    I suggest you try the other input.
  • 02-18-2011 6:17 AM In reply to
    Agree with Dillen. Sounds like you need to be using the Phono 1 input which is for T/T's without built in pre-amp.
    Regards Graham
