My latest purchase is a beocenter 7700. The device is comlpete and just about everything works. All the displays are fully functional and buttons and potentiometers aren't crackling while using them.
But this doesn't mean there's nothing to do... First of all, a thorough clean is needed. It seems like somebody has poured milk or something on to the top panels as there appears to be some very thin film of some sort of laqcuer all over the surfaces. All the panels need adjusting too. All the panel gaps are uneven and nothing really fits. And i guess i'm going to have to polish the plexiglass surfaces too.
Some real problems were found too:
-I can hear some high-pitched buzz on the background of every sound source. It gets louder if i turn the volume louder.
-The cassette player obviously needs new belts. The motor appears to be ok.
-The record player has some issues. The needle doesn't follow the track but starts to slide towards the edge of the record. Is this due to worn stylus or is this some sort of an anti-sskate issue?
After i've done these small fixes, this Beocenter seems to be in very good condition. Oh, and one strange thing is that this is a "white edition" 7700. I've understood that all of these Beocenters came with wooden panels. The white panels are well made and they don't look like someone has done them afterwards.
