Latest post 02-28-2011 5:01 PM by hugmart. 2 replies.
Page 1 of 1 (3 items)
  • 02-15-2011 5:56 PM
    BeoCom 6000 handset problems
    Good day. I have a BeoCom 6000 hanbdset that does not want to register with the base anymore. It all started with a battery problem. But the "main" handset now refuses to register. The "second" handset became the "main" and the main does not work. The screen writes "HORS DE PORTÉE" , french for "OUT OF RANGE".
    It also seems that the "menu" (black dot) button does not work. DOT 7 does not go in the menu, just writes "7" on the screen. Is this just incidental ?
    Funny fact, the handset shows the last numbers CALLER ID, the REDIAL numbers and also updates the PHONEBOOK.
    Thank you for helping.
    SERIAL : 104175688535795
    If you can't ... anybody wants to sell 1 or 2 BeoComm 6000 handset (Canada).
    Filed under: , ,
  • 02-16-2011 2:59 AM In reply to
    Re: BeoCom 6000 handset problems
    unfortunately, i don't have a constructive answer to your problem although i did encounter a similar one in the past.  i reset the base and the handset (took out battery and replaced) and it paired again.  you may also have too many handsets registered.  in any event, if you find out from the dealer that you need any parts changed, i have three or four semi functioning beocom 6000's lying around that i would be happy to donate parts from.
    BS1 x 2, BS 3, BS4, BS2000 x 3, BS2300, BS4000, BS9000, BL4, BL 4000 x 2, BL8000 x 2, BL2500 x 2, BL2000, Beocom 2, Beocom 6000 x 4, Beocom 1401 x 4, Beocom 1600 x 2, Beocom 2500 x 4, Beotalk 1200, A9 Keyring, Beo4 x 8, Beotime, Bottle Opener
    2011 Wish List: BL3500, BL6000, BL5, BL9, active link, BS5, Beo5
  • 02-28-2011 5:01 PM In reply to
    Good day, again. The repair center in Montreal wants to send the device to Vancouver (for a fee). Anybody knows where it's sent. I would like to deal witht the repair center directly.
    I should also be in Florida in April, if there is a center there, I could bring the handset with me.
    Thank you.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
