greggmay: I have tried to run the configuration guide
This is the result I got for you. The optiions seem correct but check the menu on the Avant, and make sure you have used the Audio Aux link on the converter, and not the powerlink.
************************* VIDEO SYSTEM SETUP **************************
BeoVision Avant DVD 32"
Beolab 5000
Connection Video
Connect the aerial to the aerial input of the TV-set.
Connect the Beolab to the POWER LINK socket (FRONT) on the BeoVision
using a Power Link cable.
Both Power Link sockets contain left and right channel information.
The second POWER LINK cable socket on the Beolab enables signal
loop-through to the second Beolab using another Power Link cable.
Setting switches on the Beolab
Set the INPUT LEVEL switch to position (3 lines).
Set the AUDIO/VIDEO/OFF switch to position VIDEO.
Set the MODE switch to position L or R to determine whether the
loudspeaker should serve as a left or right loudspeaker.
Selecting option on the TV-set
Option: OPTION 2, with Beo4
Press: | Display:
STANDBY + LIST at the same time | OPTION?
GO | V.OPT
2 | Observe confirmation
| from BeoVision
Programming the setup
Setup:
Procedure for the setting up of connected sources:
MENU / Setup / Connections
Fill in the menu as follows:
V.Tape AV Decoder
None None None
After filling in the menu, confirm the settings by pressing GO.
Speaker Setup.
Press: MENU, 4 (Setup), 2 (Sound)
Edit the menu using <<, >>, STEP UP and STEP DOWN.
Press: 2 (Speaker type).
Complete the menu by specifying the speaker types available in the setup.
Press: 3 (Speaker Distance)
Complete the menu by specifying the distance from the listening position to
the various speakers.
Press: 4 (Speaker level)
Complete the menu to set the sound at the same level from all speakers in
the setup.
Confirm by selecting GO in each menu to save the settings.
Note!
The Beolab display can only show: SOURCE, TRACK/PROGRAM NO. AND VOLUME.
The distance between the TV-set and the speakers shall be minimum one
metre as the speakers have no magnetic shielding
************************* AUDIO SYSTEM SETUP **************************
Beocenter 9500
Connection Audio
Connect the aerial to the aerial input of the audio master.
When using the remote control mute function, sound is
restored by turning the volume up or down.
Selecting option on the audio master
Option: OPTION 0, with Beo4
Press: | Display:
GO | V.OPT
LIST | A.OPT
0 | Observe confirmation
| from AudioMaster
********************* AUDIO/VIDEO/LINK SYSTEM SETUP *******************
Connection
A BeoLink Converter is required to be able to connect the video- and
audiomaster, part No. 1161166/1161466
Connect the AUX/TV socket of the audiomaster to the BeoLink
Converter's AUDIO AUX LINK socket using a 7/7-pin DIN cable.
Connect the BeoLink Converter's Master Link socket to the Master Link
socket of the TV-set using a BeoLink cable.
Connect a POWER LINK socket of the audiomaster to the POWER LINK
socket of the BeoLink Converter using a Power Link cable.
Note!
No Audio Timer recording from 3-digit program numbers is possible,
e.g. from the Satellite receiver in BeoVision.
In some cases it may be necessary to apply a long standby pressure to
switch off a product.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo4
The following remote controls may also be used:
Beo5
Setup for Beo4 remote control:
Beo4's "LIST" must contain the following items in order to be able
to operate the Main Room products.
FORMAT STAND SPEAKER CLOCK
CDV (only with S/W lower than 4.0 in Beo4)
MONO (changed to SOUND with S/W 4.0 or higher in Beo4)
TURN RETURN
(RESET)
A.SETUP (only with S/W 2.0 or higher in Beo4)
AV (only with S/W 4.0 or higher in Beo4)
See Beo4's operation manual page 10/12 on REMOVE and ADD functions
from/to the List
Note!
Beo4 must be equipped with software (S/W) 2.0 or higher to operate:
Sound setup on the Audiomaster.
The software version can be read on the Beo4 display by
pressing (STANDBY LIST) and then (MENU GO) at the same time.
Order No. 8001827
Andy T.
