Latest post 02-15-2011 7:54 AM by stefan. 4 replies.
Page 1 of 1 (5 items)
  • 02-14-2011 7:19 PM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Projector install with bvis 7-40 mk3
    Hi
    Looking for some advice,we are going to be doing an install of some bang & oulufsen equipment most of it is straight forward, it is the main room, where the cust will have a beovision 7-40 mk3, they have a projection screen already installed, which has it's own remote plus it also has rs232, they also have a projector Epson TW440 or the TW5500, will these work ok with the beovision 7-40 mk 3, would appreciate any help
    Kai :)
  • 02-15-2011 4:06 AM In reply to
    • LC
    • Not Ranked
    • Joined on 11-23-2010
    • London
    • Posts 24
    • Silver Member
    Re: Projector install with bvis 7-40 mk3
    yes it should be fine, you will have to manually turn on the projector or program direct control off the beo5 or use a lintronic box.
  • 02-15-2011 5:37 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    I recommend a Lintronic - 238 box for cinema control. The box can be triggered by the cinema control outputs of the BV7-40 and can control the projector and the motor screen by IR or RS 232.
    More info: http://www.lintronic.dk/AppNote_BeoSystem_RS232_IR.pdf
                    http://www.lintronic.dk/Support.asp?Supported_BRANDNAME=EPSON
    My setup even controls light and blinds. Works great.
    Stefan
  • 02-15-2011 7:36 AM In reply to
    • kai
    • Posts 81
    Thanks for that, if the rs232 from the projector then goes into the screen then to bvis 7 would that trigger, the screen to come down and the projector to switch on, or would I need to use the linntronic box??
    Kai
  • 02-15-2011 7:54 AM In reply to
    • stefan
    • Posts 1,733
    No. BV7 just delivers a close/open contact. This contact - there are two actually - trigger the Lintronic box, and the box will control all your cinema devices via a macro incl. the popcorn machine. See the Lintronic instuction manual.
    Stefan
