Bit confused now.....if you've already installed it, and it works like a dream, why do you need suggestions/solutions for local inputs ?
For anyone else interested..Sonos is great when used with Beolabs too -
A while ago, I installed a system that was Beolab 4000 speakers in several rooms, all on ZP90 zones, driven by a Beosound 4 in the living room. Even in that room, the blab4's were on a zoneplayer....th beosound providing fixed line out, not powerlink.
The reson was the wall between the kitchen and the living room was "too thick" for wireless
This was a stately home, split up into apartments - very nicely done - loads of period coving etc and NO option to use cables.
Needles to say, when i took round a wireless 1 dem kit to test, it dropped out repeatedly because there was..... a wall in the way.
I thought it may be an issue, so we popped round to try it before specifying the system....and yes, a wall, a 25ft iving room and a kitchen cupboard were just too much for the poor wireless 1 to cope with. It was a brick wall, in fairness.
ANyway, specified with sonos, ordered, paid for, installed...and everyone way happy.
The Beolabs/beosound looked stunning.
The customer was delighted - NO link wires, all controlled via their ipod....superb.
Also happy with the only "compromise" -ie, use close-up operation/beo4 to turn on & control the CD/DAB....but in reality, it is 95% streamed content and internet radio that is played. The odd Cd played, and a very occasional LP.
All that can be seen is B&O....the client essentailly bought B&O, and we specified sonos instead of Wireless 1's as infrastucture
They probably couldn't tell you the name sonos....the system is used via an app, and it all looks and sounds like B&O...so its a B&O system...the sonos stuff is just, in effect, interconnect and software.
Such a shame there isn't an in-house B&O solution like this....it would be SO popular.
As i've said before, if a previoulsy unkown brand can do this so well, about £300 per room ( plus speakers) ...what are B&O up to ???
