If I can just re-ignite this debate?
I have just got my PS3 and like 'rednik' I have a BV7 (Mk1) and Sky HD. At the moment the Sky HD is connected to the DVI port with a SCART connection for the sound.
I tried to connect my PS3 using a component cable from B&O, but cannot get any display from it at all.
I connected the PS3 via the normal AV cable into AV1 and it worked OK but no sound. I then connected the HDMI/DVI cable to the PS3 and have got a beautiful HD image (but as I expected no sound). But whenever I select the composite connection option from the PS3 menu the screen just goes blank. Is this because I haven't set it up correctly with the BV7 - ideally I wanted to press the V MEM button on my Beo4 to get the PS3 up because I currently press DTV for Sky, and CD/A MEM for my masterlink connected BS3200.
Can anyone help me, or suggest an alternative way of getting a HD input from my Sky HD and PS3 simultaneously without having to fiddle around swapping cables over every time?
Many thanks.
