Hi, here are a few random pointers....
- Their former designer Georg Jensen, has now designed kitchenware: http://www.google.com/search?client=safari&rls=en&q=georg+jensen+kitchen&ie=UTF-8&oe=UTF-8#sclient=psy&hl=en&safe=off&client=safari&rls=en&biw=1230&bih=702&tbs=shop:1&q=georg+jensen+kitchen&aq=f&aqi=&aql=&oq=&pbx=1&fp=a494c57c705f04b ... and I believe a range of kitchen appliances for maybe Miele...
- There has been two emblematic designers working for B&O, that I think you need to do some research on: Georg Jensen and David Lewis (the current one)
- Georg Jensen, is well knows for its rectangular shapes, with panels of black glass and aluminium. Look at the Beosound 9000.
- The black glass panels are often touch sensitive.
- LEDs and LED displays are often used.
- Important: A red dot (LED) means the device is on standby. This is used across the range (TV, Hifi, Speakers). The Red dot button on the remote is the Standby button.
- The use of scroll-wheel/navigation wheel has been pioneered by B&O. Master Control Panel 6500, Beocom 6000, Beocom 5, Beocenter 2, and a lot more...
- Materials are of very good quality: Glass, Aluminium, and when they use plastic, it never imitates another material. Plastic is often "soft touch" (touch a Beovision 8 or a beocom 5)
- Their products are heavy, solid, and products that you can hold in your hand are well balanced. Their remote controls use rubber buttons, arranged in easy to remember way, so you can feel them and use them without looking at them.
- B&O produce their own aluminium parts as their is no other factory in the world that can process it as precisely as they do. They produce parts for BMW (for the car itself, not an audio product).
- The shape of some of the products is inspired by some other objects: Beolab 8000 = organ pipes, Beovision 10 = Painting, Beolab 11 = Tulip, Beo 1 remote... well I let you guess
- Shapes are pure and geometrical.
- The shape is designed first and then the engineer have to produce the electronic that fits inside it.
- Products are not designed to be in fashion and a design is often sold for 15 years (the electronic may evolve).
- User interface is always very simple. Buttons that are not active are dimmed. There are very few buttons as buttons have multiple functions depending of the context. (modal interface)
- Very important: There is often something "Magical" in a product that wows the user. Often it is a moving part. TV's stands turn. Glass door opens when you wave your have. Angel wing open (Beocenter 2). CD slots pop from nowhere (Beovision 7). Screen and scroll-wheel are merged (Beosound 5)... and there movements happen very silently. To achieve this silent movements, B&O produce their own plastic parts as no other factory could produce them so precisely.
- Integration: Their products work with each other. 1 + 1 > 2
- The WAF (wife acceptance factor): Their products are often bought by men, but are designed to be accepted by their wife.
I hope that will help you.
p.
