Latest post 02-09-2011 11:27 AM by Stan. 3 replies.
Page 1 of 1 (4 items)
  • 02-08-2011 12:30 PM
    Beolink Active into Aux in?
    Dear Spezialists,
    I am thinking about a way to add a speaker for a non B&O LCD which can play also sound from my main room Audio via Masterlink.
    Now I do have a BL2000 for Audio but TV sound is missing.
    I know this works with BL active (which I have) and a pair of Beolabs. But I wonder if there is a way to use a Beosound1 (Aux in) as well.
    Tv and mainroom audio would go into BL Active and then into the BS1.
    Would this work? Which cable would I need?
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 02-08-2011 2:28 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: Beolink Active into Aux in?
    I'm currently listening to a BS1 being driven by a BL Active.  I use a PowerLink to Aux cable from Sounds Heavenly.  The only tricky part is that both the BS1 and BL Active respond to the remote... at least, this is how it worked until I put the BL Active into "Link" mode (forget the option number)... but now I press "Link-CD" to listen to masterlink CD and "CD" to listen to BS1 CD.
    Stan
  • 02-08-2011 3:18 PM In reply to
    Hi Stan.
    Do you also use the PC port of BL active?
    Heribert
  • 02-09-2011 11:27 AM In reply to
    • Stan
    • Posts 593
    • Gold Member
    I have in the past.  I'm not currently.  If you are somehow worried that the combination of PC port + PowerLink to Aux would be problematic, it should not matter as the Active has no idea it is not talking to a BeoLab.
    However, you have just reminded me of a new application for this PC port (connect my turntable so I can listen via BS1) so maybe I will set this up in a few days and let you know.
    Stan
