Hello all,
I have a B&O Mx5500 and a BEO link 1000 controller.
I am trying to connect a sky sat box to the television using a scart cable.
The problem is that the TV will only recognise the sat box if I remove the power cord from the sky box and then replace it.
If I just switch the sat box on from standby the television does not recognise it.
Is this a setup problem with the television? If so, how do I access the setup menu using the beolink 1000.
Sparkymark
