1st March February 2012
Latest post 02-08-2011 1:20 PM by Evan. 9 replies.
02-07-2011 8:58 AM
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
Does anybody know BeoLab 9's max SPL?
As B&O is providing less and less technical information, I was wondering if anybody knew the max SPL of BeoLab 9?
We know BeoLab 3 goes up to 94 dB, and BeoLab 5 to 105 dB, but how does BeoLab 9 compare?
I'm just curious..
Reunion Island is greeting you!
Dennis
- Joined on 02-01-2009
- Denmark
- Posts 172
Re: Does anybody know BeoLab 9's max SPL?
Bang & Olufsen has the answer!
Specifications - Beolab 9 (Bang & Olufsen)
Regards
Loudspeaker
EDIT: Beoworld has the answer too! Specifications - Beolab 9 (Beoworld)
I was borned with a Beolink 1000 in my hand!
Ever seen a Beomaster 6001? I have one! Look here.
Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
Wish list: Beolab 2,
Doctor
- Joined on 09-14-2010
- Posts 555
To be fair, I think this only gives the sensitivity. I'll see if I can find the max sound level when I get home tonight!
Doctor
- Posts 555
The figure 103 seems to ring a bell though!
Dennis
- Denmark
- Posts 172
I think I was too fast there!
Chrisreunion
- Reunion Island
- Posts 677
It's funny how much more info you can get about BeoLab Penta in terms of SPL, distortion rates, S/N ratio for the amp, and none of this is available for the new speakers..
I would assume BL9 to have an SPL around 100 dB, since it fits between BL3 and BL5, but I read somewhere that it didn't go as loud as BL1..
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Input sensitivity isn't the same as maximum SPL.I don't know what the maximum SPL of these sepakers are...I think most speakers are enough. The Beolab 5's have close to extreme SPL's.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Alex
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
B&O don't tell you the % distortion when measuring their maximum SPLs, and whether it's peak output or continuous output. Continuous output is often at least half the peak output (6dB lower), and most manufacturers measure their maximum SPLs at distortion levels where you wouldn't even want to listen to the speakers, so what's the point?
The other crafty thing manufacturers often do is publish the calculated maximum SPL, as opposed to the real-world measured maximum SPL. I'm not suggesting B&O are doing this, but again, SPLs are a figure to take with a pinch of salt.
What I do know is that both the BeoLab 9 and BeoLab 5 go far louder than you would ever want in a domestic setting, the BeoLab 5 especially. Neither of them are on the same scale as proper PA, but incredibly loud nonetheless. BeoLab 9s really shriek when you turn them up high, so I wouldn't want to get them right to the top of their range anyway, but BeoLab 5s go all the way up and still sound incredible, even when they're pulling back the levels going to the drivers...
Weekly top artists:
Doctor
- Posts 555
I agree with Alex. The Beolab 5s are in a different category to all the other speakers - they just get louder with no distortion - the problem with them is you end up playing them rather louder than you imagine - woe betide the neighbours!
All the other modern speakers shriek as they get to the top of the volume levels. The MS150s did this as well though my M100s do not seem to. The only other speaker that did not seem to shriek that I have tried in the B&O later ranges was the Penta. I did talk to someone at Struer about this and he put it down to the protection circuits which are less strict on the Penta - he intimated that the Penta was more likely to damage drivers at very high volumes than the others but not being an electronics whizz, I would not like to comment!
On a general note, speakers with ABRs seem to be worse at high volumes - Beolab 3s really get messy if you play them too loud though they are wonderful if not stretched.
Page 1 of 1 (10 items)
