Latest post 02-07-2011 7:52 AM by Saxpy. 8 replies.
Page 1 of 1 (9 items)
  • 02-06-2011 8:13 AM
    • Saxpy
    • Not Ranked
    • Joined on 07-10-2007
    • Stockholm, Sweden
    • Posts 24
    Connecting two pairs of speakers and switching from one to the other
    I was wondering if there is any way of hooking up two pairs of Beolab speakers to a B&O stereo(2500/Ouverture or 9500) and then choosing which pair to use using the remote? I have a large room and would like to use different speakers depending on where I sit in the room.(First pair is for use when watching TV and the other of listening to music)
    I guess I could connect one pair over a link-kit but that just seems like a hassle. Is there any other way?
  • 02-06-2011 8:59 AM In reply to
    Re: Connecting two pairs of speakers and switching from one to the other
    Actually not using a link kit is a hassle. It's designed for exactly this purpose. Then you can choose the link option and keep them from responding to one another's IR commands.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 02-06-2011 10:07 AM In reply to
    • Saxpy
    • Not Ranked
    • Stockholm, Sweden
    • Posts 24
    Hmm... Maybe I should just set up two different systems in the same room and let one run the tv-system and the other one the audio system.
    Can't have to many b&o-stereos in one room, right? Wink
  • 02-06-2011 11:28 AM In reply to
    You could go the low tech route of simply turning one pair off when not needed.  I have installed many systems like this ( mainly in "L" shaped rooms, or "knock through" living / dining rooms)
    Easy to do with powerlink supplying all speakers with L&R - just switch of the mains supply for the pair you don't want to hear.
    You can "daisy chain" Beolabs - many have two sockets.
    You can also get B&O made splitters, or you can just splice the PL cables ( care needed but easy and effective)
    The only real drawback compared to a beolink is no different volume control is available for pair A and pair B when they are all on - but maybe not an issue in the room you describe.
    Also, if you have a video source ( or some newer audio systyems) , link would offer the option of different content in pair A and B - but in a one room system, this would sound a bit odd!!!
  • 02-06-2011 2:47 PM In reply to
    • psand
    • Not Ranked
    • Joined on 05-05-2010
    • Stockholm, Sweden
    • Posts 48
    • Gold Member
    I'm a bit intrigued by your wish to avoid the link-kit (by which I understand you mean the Beolink Active). I have something of the same problem, as I have just acquired a pair of Beolab 1 speakers, which I want to use for a special music listening position in a rather smallish room which already has a pair of Beolab 4000 placed in a bookshelf.
    The obvious solution for me is to connect the Beolab 1 speakers to a Beolink Active, and activate them with a LINK command.
    Setting up a separate video and audio system seems to defeat the purpose of Beolink integration. Why on earth would you want to do that?
  • 02-06-2011 3:30 PM In reply to
    • Saxpy
    • Not Ranked
    • Stockholm, Sweden
    • Posts 24
    I was just trying to avoid buying yet another box... Indifferent
  • 02-06-2011 3:51 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Saxpy:
    Hmm... Maybe I should just set up two different systems in the same room and let one run the tv-system and the other one the audio system. Can't have to many b&o-stereos in one room, right? Wink
    Partially wrong, fortunately ...
    You can have an audio system (with speakers connected)
    AND a TV (with / wthout speakers connected)
    AND, furthermore a (pair of) Link-speaker(s)
    in one room - still beeing able to control the sound of any of these zones independently.
    Depending on your components this can be done either by ML or by ML+Datalink.
    Post a list of your audio- and video componets and your speakers.
  • 02-07-2011 7:47 AM In reply to
    I could imagine a setup with SPEAKER 4 option and then fade the front or Rear speakers that just one pair is working.
    Would be a very easy solution - never tried but see no problem.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 02-07-2011 7:52 AM In reply to
    • Saxpy
    • Not Ranked
    • Stockholm, Sweden
    • Posts 24
    I don't have a B&O TV, only audio products.
    Penta III, Beolab 4000s, Beosystem 9500, Beosound Ouverture and a Beocenter2300.
