Latest post 02-06-2011 4:26 PM by folkdeejay. 7 replies.
Page 1 of 1 (8 items)
  • 02-05-2011 3:55 PM
    Difference in Bv1 models
      What are the differences between the bv1 models? bv1, bv1L, bv1LS?  Cheers Nick
  • 02-05-2011 5:17 PM In reply to
    Re: Difference in Bv1 models
    BV1 No Masterlink
    LS Have masterlink and  L have Masterlink. Not to sure about the difference here.
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 02-05-2011 5:28 PM In reply to
    LS is Link Slave. Used as bedroom or similar slave TV when linked.
    Regards Graham
  • 02-05-2011 8:15 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    "LS": Could be used "STAND ALONE" or as a "LINK SLAVE" to acces sources of a "MAIN-TV / AUDIO System"
      via ML/Antenna.
    "L" :  If equipped with a ML module it could be used either as a "LINK SLAVE" (V-Opt 5/6)  or as a "MAIN-TV"
    (V-Opt 1/2).
    "L" : If equipped with an optional modulator module HF distribution to Link-TVs was possible.
  • 02-05-2011 8:58 PM In reply to
    • benjnz
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Auckland NZ
    • Posts 392
    • Gold Member
    Oh well I have a 1 without that.
    Does anyone have a ML module that would go in a BV1, as I'd like to hook it all up
  • 02-06-2011 4:13 AM In reply to
    thanks for the replies, the reason I ask is I bought a bv1 which i believe was a ls set and so did the seller! It turned out to be a bv1 with masterlink module.  I have a bv1L in my bedroom aswell. So am I worse off or better off? I noticed the bv1 has powerlink sockets my bv1L hasn't.
    Cheers Nick
  • 02-06-2011 3:09 PM In reply to
    • kawo
    • Joined on 04-17-2007
    • Posts 516
    I have one of the later models, with no ML module build in, but a ML socket. Took some time to figure out that I had to get the module and the socket was without function. Nice! But installing the module was quite easy.
    The earlier models can not be upgraded.
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 02-06-2011 4:26 PM In reply to
    These are a surprising amount for a small PCB - about £175UK as I recall.
    Plus fitting - unless you do it yourself.  The link board just clips into a multipin holder - rather like fitting PC memory.
