I have some trouble with a Beogram 2000 and Beogram 1000 (the early 2000 with the mechanism similar to the 1000).
Sound reproduction is fine, but once the motors start spinning they are rather noisy and pretty annoying.
The motors itself are quiet. It's the idler wheel that makes all this noise. I had a BG 1800 with the same idler wheel and it was almost inaudible, so something has got to be wrong here.
Is there some way to adjust the idler wheel? Are the plastic bearings worn? By the way, do you have to lubricate these bearings?
I suspect the idler wheel is not perfectly round. Both Beograms were stored for several decades (motors were initially seized on both), maybe the pressure on the rotor left a mark? The aforementioned 1800 was used frequently without ever being stored for a longer period of time.
Any ideas?
Thanks.
