Latest post 02-05-2011 5:15 PM by Medogsfat. 4 replies.
Page 1 of 1 (5 items)
  • 02-05-2011 11:11 AM
    Beovox P45 black
    Hi.
    I just got myself some white P45 speakers which are black. Confused? I am. I know they're white because it can be seen on the inside when the grill is removed and there is white under a small chip on the outside. So perhaps someone painted them black. Well I don't think so as the finish is very even with just the right sheen. So my question to the wise here is has B&O ever been known to do custom finishes.
    Also, three of the grill cover posts are broken. Does anyone know of a supply or will I have to buy some P30s or other for spares.
    They sound great by the way and I will stabilize the bass drivers right after I've done the same with my S45s.
    Thanks for any insight you can give.
    Trevor.
  • 02-05-2011 11:21 AM In reply to
    Re: Beovox P45 black
    I would imagine that these has been done after purchase. I think if B&O did a custom finish, they would not start with a white set. Being the proud owner of a blue Beolab 2, I can vouch that after market customisation can be very professional.
  • 02-05-2011 12:51 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Hi Trevor, can you show a picture of the peg you need? Also how long an unbroken one is? Might have a few spare ones.
    CraigSmile
  • 02-05-2011 4:04 PM In reply to
    Thanks for the replies guys. Craig here is a picture of one. Length is 26mm.
    http://freespace.virgin.net/trevor.pvr/peg/P45_peg.jpg
    Trevor.
  • 02-05-2011 5:15 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Hi Trevor,
                   the same fixing pegs were used on the X25/35's as well as the S series of speakers which have the single panel grills (as opposed to the 2/split grills as used on the S55's etc...). May be of use if you find some cheap ones.
    Agree with Peter though, these have probably been painted by a talented individual rather than purchased as such. A real shame though as white seems to be the new black...
    Chris.
