Latest post 03-27-2011 9:35 AM by Trigi. 5 replies.
Page 1 of 1 (6 items)
  • 02-04-2011 8:41 AM
    B&0 beocord 8004 hx Tape Deck
    I Have a B &O   8004 hx beocord it need new drive belts, I have been told that Martin Olsen (known as 'Dillen is the man who knows about these parts could he please get in touch with me
    Mike Clare email mike@ussltd.co.uk   Many Thanks
    Filed under:
  • 03-27-2011 5:23 AM In reply to
    • Trigi
    • Not Ranked
    • Joined on 01-29-2010
    • Ry, Denmark
    • Posts 21
    • Gold Member
    Re: B&0 beocord 8004 hx Tape Deck
    Hi Mike.
    ive just send for some belts for a 8004, I had to messure them myself, and as allways I order an extra par.
    If they fit, they usally do, Ill send u the extra par.
    The schuld have been here by now, -expecting them any day.
    ill be back.
    Peter, Denmark
  • 03-27-2011 6:54 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Please note that not only the size but also elasticity needs to be correct. It's particularly important in
    these decks with motors using sintered bronze bearings and a sideways pull to the pulley. With a too low
    elasticity the poreus bearings will wear down at an alarming speed and new motors are no longer available.
    I've seen a couple of cases where off-the-shelf types has been mounted and I have a couple of bad
    motors lying around with bearings that had their bearings worn to the point
    of blocking the spindle with burned commutators and coils as the result.
    If you need it, I can supply correct belts, produced to a slightly narrower width to also guarantee that the capstan
    belt doesn't rub on the support plate which can be an annoying and very difficult to diagnose source of wow.
    Mounting instructions with photos and english text can be included.
  • 03-27-2011 8:58 AM In reply to
    If the source of wow is the belt, how does it sound like? My BC9000 has the issue, I can't seem to find the thing causing it... It is altering speed (up and down) about 3-4 times a second, it sounds like a subtle vibrato. The deviation is not that great, it is not over 5% I think.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 03-27-2011 9:33 AM In reply to
    • Dillen
    • Posts 5,008
    It's normally a slower wow.
    3-4 times per second is more like a vibrato as you suggest and I would suspect
    the capstan itself, dirty or bent.
  • 03-27-2011 9:35 AM In reply to
    • Trigi
    • Not Ranked
    • Ry, Denmark
    • Posts 21
    • Gold Member
    Oh Oh..
    Thanks Martin. In fact it is a BC9000 im trying to repair whit new belts. ill contact u on PM to get the just-rigth size.
    And for Søren, I have a extra complete motor/deck basement for a BC 9000 (no belts either), u can have it and se if its any better than urs.
    Peter, Ry DK
