Latest post 02-05-2011 3:14 PM by Ehlerz. 3 replies.
Page 1 of 1 (4 items)
  • 02-03-2011 6:00 AM
    • js
    • Top 500 Contributor
    • Joined on 09-07-2007
    • Brussels
    • Posts 208
    • Silver Member
    Un-compress Apple Lossless etc.
    Dear all,
    Is it possible to copy Apple Lossless, AAC and MP3 files from iTunes on a CD in normal, non-compressed audio CD file standard?
    The purpose is to be able to play such audio CD on an older Beocenter 9000 or 9500 (stand-alone: not streaming to this one).
    Thanks, js
  • 02-03-2011 6:11 AM In reply to
    Re: Un-compress Apple Lossless etc.
    Yes you can do it withing iTunes.
    Create a playlist with all the songs you want to copy on CD.
    Then click on File/Burn to Disk.
    Choose the "Audio CD" format when prompted.
  • 02-03-2011 10:35 AM In reply to
    • js
    • Brussels
    • Posts 208
    • Silver Member
    Phil, thank you for your help.
    Would you know how to do it for FLAC files (which iTunes cannot read) as well?
    Thanks again, js
  • 02-05-2011 3:14 PM In reply to
    Hi Js
    Use Fluke for importing Flac files into Itunes and then burn them from within Itunes as the case is with lossles.
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
