Latest post 07-27-2011 7:38 PM by h1npw. 54 replies.
Page 3 of 3 (55 items) < Previous 1 2 3
  • 04-15-2011 5:00 PM In reply to
    Re: Painting Beolit panels
    tournedos:
    Not to mention "does it work". It's flippin' endless.
    Sounds fantasticSmile
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 04-15-2011 5:25 PM In reply to
    Leslie:
    Some pictures from the 700 I got. It still has to be cleaned and some dust particles behind the perspex which has to be removed. How to do that?
    @Nickyg63, Thanks for your offer but no need to be repainted, still looks excellent!
    @Soren, Will do my best to make pictures when it has been restored or better, cleaned.
    Be carefull dismanteling the perspex, as I see it you will have to take of the side pieces and the frequency curser to get at it.
    Battery tubes: look for posting tubes for posters and rolled up documents, or maybe the tubes from kittchen paper roll can fit.
    Looking forward to see the innards.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 04-15-2011 5:32 PM In reply to
    Thanks for the tips Søren! Have to restore lots of things, BM2000, Beovox2500 etc. etc.
  • 07-26-2011 4:03 PM In reply to
    Hi all!
    I have a Beolit 707 and I am buying an additionnal Beolit 400, because the 400 has 3 Watt output against 1 Watt in the 707.
    Now, are the front covers between 400 and 707 interchangable???
    Thanks,
    Bruno
  • 07-27-2011 7:38 PM In reply to
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    I would be astonished if the power output between the different models wasn't the same -  I assume you've seen the 3W figure from the product section on this site.  I think it's either a typo or confusion between continuous and peak power... certainly Beocentral say they were all 1W.
    Cheers
    Nigel
