1st March February 2012
Latest post 07-27-2011 7:38 PM by h1npw. 54 replies.
02-03-2011 5:50 AM
h1npw
- Joined on 04-16-2007
- A cricket ball throw from Trent Bridge
- Posts 776
Painting Beolit panels - see the results!
I seem to remember a thread on this, but can't seem to find it (maybe lost on the old forum)
Has anyone done this and can they give me some idiot proof guidance of how to do it in terms of cleaning, prep, what type of paint, lacquer etc.
I want to acheive as close as possible to the original B&O black. Currently they're the most disgustiing shade of "mustard that's been left with the lid off"!
Cheers
Nigel
ajames
- Joined on 05-04-2007
- Posts 275
Re: Painting Beolit panels
I would be interested also - I have a mustard Beolit 707 that is faded - I had thought of Metlic Purple or Blue would be different.
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
Stonk
- Marlow, Bucks, UK
- Posts 1,688
Well I have a spare red cover that has a hole drilled into the side by a previous owner so he could fit a thumbwheel to tune it after the string broke
One of you is welcome to have it for free to test the results. Just PM me an address & I'll pop it in the post.
However, I personally wouldn't want to buy a painted Beolit so only do it if you intend to keep it. You could always ebay it and buy another in the colour of you choice or buy a broken/tatty one with good panels then swap the panels over and resell again.
Incidently the FM only model's side panels won't fit the AM/MW/FM models
Steve
If you think nobody cares, try missing a couple of payments.
h1npw
- Posts 776
Hi Steve
I've sent you a pm with my address - many thanks
Cheers
Nigel
SecretSheep
- Joined on 05-28-2008
- In the field outside 'The Farm' - Struer
- Posts 56
What you need is Nextel paint - as used by a well known Danish manufacturer on some models.
They think we're just eating grass....
h1npw
- Posts 776
Hi Nick
Help couldn't get much closer than that! Sounds great. As soon as I get the panel I'll drop you a pm.
Need some bodywork doing on my 18year pld BMW too!
Cheers
Nigel
Nickyg63
- Joined on 08-28-2007
- Nottingham
- Posts 628
h1npw:
Hi Nick
Cheers
Nigel
No problem, let me know when it arrives!!
Stonk
- Marlow, Bucks, UK
- Posts 1,688
It went off 1st class today
h1npw
- Posts 776
And thanks to good old Royal Mail, it dropped through my letterbox this morning. Many thanks Steve.
Nick, I'll drop you a pm with my phone number.
Cheers
Nigel
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
I'm surprised that no one else has yet found the "easy fix" for faded panels amongst the talent that is the Beoworld membership.
A simple thorough clean followed by a couple of fine coats of clear lacquer usaully does the trick. You need to be VERY sparing when applying to prevent the holes in the grills becoming clogged/blocked.
You can judge how they will look before you do this by simply wetting them - this is the same finish that will be achieved with clear lacquer.
Chris.
Nickyg63
- Nottingham
- Posts 628
Hi Nigel,
I think I have found a perfect colour!! not quite a navy blue a bit lighter in a matt finish! i am going to get it painted tomorrow and get you to see what you think cheers Nick
h1npw
- Posts 776
Can't wait!
I can feel some photo-posting coming on.....
Cheers
Nigel
h1npw
- Posts 776
Wow!
That looks great Nick
Can I pop round tomorrow evening with my panels?
Cheers
Nigel
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
Yeah that looks really good
My B&O: 2009 Catalogue and Pricelist
jahur
- Joined on 02-07-2011
- planet zonk
- Posts 161
i have a black paneled beolit and i use auto glyms bumper gel to nourish the plastics. i brought it back from the brink of no return, it works a treat!
to clean the magic doors on my beocenter 2300 i use auto glyms glass polish. apply to glass leave till it dries and its as simple as wipe off and then just buff to a nice deep shine.
to clean the avants i use mild water with a small drop of washing up liquid just wipe the screen, plastics then wipe with a dry cloth and i tell you this it cleans through fingerprints like a hot knife through butter! top tip, make sure you wring the cloth out before cleaning of excess water.
hope these help!
jason
(formerly nokinnikon from the old site)
Medogsfat
- Posts 4,045
h1npw:
That action is REALLY unusual Nigel. The mustard coloured Beolits generally struggle to get anywhere near the price of other colours.
Not sure about them being rare either (sellers description), I've seen loads in that colour.
Chris.
burantek
- SE USA
- Posts 6,214
Call me goofy... I don't own a BeoLit -but if I did: It would be MUSTARD!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
burantek:
I have one 707 in that colour and have to say I like it as well I also have a black one and that was much harder to clean properly. I'll probably try that car wax approach later on it.
I can almost understand that oddball auction result seen above, as that particular radio seems extremely nice, apart from the handle and the battery tube.
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
burantek:
Me too. I'm starting to like the yellow variety of products.
h1npw
- Posts 776
See also 2 other threads I started...
http://forum.beoworld.org/forums/t/37950.aspx
http://forum.beoworld.org/forums/t/37988.aspx
Well,
due to the incredible generosity of Trigi (Peter, from Denmark), Nickyg63
(Nick, from Nottingham), Stonk (Steve from Marlow) and help from Tim J., I now
have a fully working Beolit that looks the cat's whiskers (so much nicer than
the d's b....)
I
realise that some will say the colour is not original, nor to their taste, but
I (and more importantly SWMBO) love it.
A
very sincere thank you to all who helped me with this project. To say I'm a
happy bunny doesn't come close.
Cheers
Nigel
Ta-da!
And where it will entertain me in the shower room!
