1st March February 2012
Latest post 02-03-2011 8:05 AM by Emil. 8 replies.
02-02-2011 4:35 PM
Bentleyman
- Joined on 12-29-2008
- Rochdale
- Posts 367
Hello All,
Could anyone explain the information contained within the 'Service Counters' screen on TV's?
Audio (Days) ?
Video (Days) ?
Boot Counter ?
On ( x10 ) ?
Does a set displaying say 2,500 'on's' mean that it's been switched on 2,500 x 10 times? = 25,000 times?
Cheers,
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
Re: Service Counters on TV's
Yes, that's correct - it's been switched on 25,000 times. I'm guessing this is an early Avant or such like?
If so, think of it like this..
7 days in a week, 52 weeks in a year, over 15 years. That's around 5,500 days.
Admittedly it's a high count, but it's not beyond the realms of possibility to turn your TV on/off 5 times every day..
Lee
PS - On BV7's especially, a software error can cause the 'Boot Counter' to go nuts and record some astronomical amounts! Any crazy readings should be ignored.
Bentleyman
- Rochdale
- Posts 367
9 LEE:
Hi Lee,
Actually the set I was just browsing on ebay is a BV6 26" - and the seller is describing it as 'low used'... ??
A set being switched on 25,000 times is a heck of a lot aint it..?? And being a BV6, it cant be massively old either...
http://cgi.ebay.co.uk/Bang-Olufsen-BeoVision-6-26-black-silver-boxed-/150557593333?pt=UK_AudioTVElectronics_Video_Televisions&hash=item230dee8ef5
Also the Audio Days, Video Days & Boot Counter...? What do they mean exactly?
Cheers,
Michael
BS 7000, BS 5500
9 LEE
- Moderator - UK
- Posts 5,223
I see the boot counter is reading a massive amount, so i possibly suspect the readings have gone bonkers too!
It's had next to no Audio use, plus its only had 37 days use (37 x 24 hours = 888 hours) which is very low.
25,000 turns on means it was turned on/off 28 times an hour (once every 2 minutes) for it's whole life - which is obviously wrong.
I reckon it's had a software 'tizzy' which has screwed up the readings. An engineer on here may back me up (or shoot me down!) on this one..
The seller is a decent bloke, so if there are any past dramas i'm sure he's unaware - otherwise he wouldn't have published the counters!!
Lee
Bentleyman
- Rochdale
- Posts 367
Thanks for that explanation Lee
Just had a look at my service counters on my 2003 BV-5, they read :-
Standby (days) 2691
Audio Mode (days) 0105
Video Mode (days) 0329
On/Off ( x10) 0667
Considering it's now in it's 8th year of course, how would you rate it's usage?
Low / Medium / High ?
Regards,
Michael
BS 7000, BS 5500
9 LEE
- Moderator - UK
- Posts 5,223
As a rough calculation i'd do the following..
the set is roughly 8 years old. So.. (and this is a rough calculation before anyone corrects me..)
365 (days a year) x 8 = 2920
It's 'clocked up' 329 days. so 24 x 329 is the hours it's been actually watched, which is = 7896 hours
So, 7896 divided by 2920 gives around 2.70 hours a day use. This, to me, is low to the lower end of medium daily use.
From memory these panels are made to last 60,000 hours at least, so just under 8,000 hours means it should have plenty more life in it. The BV5 is by far the most reliable TV i've ever dealt in. I can't rate them highly enough.
Lee
Bentleyman
- Rochdale
- Posts 367
9 LEE:
Lee,
Very interesting and useful to know how the calculation is broken down & worked out.
Many thanks for explaining that so clearly & concisely
Michael
Michael
BS 7000, BS 5500
9 LEE
- Moderator - UK
- Posts 5,223
My pleasure!
Lee
Emil
- Joined on 05-18-2007
- Stockholm, Sweden
- Posts 98
As for the reliability of the BV5 - there seems to be at least some of us who has experienced what probably is to be regarded as a power supply problem resulting in a high, buzzing noise when showing bright pictures. If my memory does'nt fail I think my 2002 MK 1 BV5 has been used for 222 days in video mode.
http://forum.beoworld.org/forums/t/34151.aspx
Page 1 of 1 (9 items)
