Hi All,
I have Beoloab 3000 connected to BS9000 and was wondering how to get the display working. I have checked the forum and also both user manuals but still no display ....
I have 8pin powerlinkcables and the speakers are set to 'audio'
Am I correct to understand that all should work, or should I chang some set-up to my BS9000?'
If yes, how
Maybe the displays are broken )on both?) how to test this?
Thanks .. and good luck with tonights pricedraw!
BS9000, Beolab 3000, Beocenter 7002, RL60.2, beo4, BV10
