Latest post 02-08-2011 9:33 AM by TheMajor. 7 replies.
Page 1 of 1 (8 items)
  • 01-31-2011 12:55 AM
    • jthorn
    • Not Ranked
    • Joined on 11-30-2010
    • Posts 3
    BeoLab 2 or 11
    I have ordered a BeoVision 10-46 and a pair of BeoLab8002.
    The BeoLab8002 will be paired with my 3200 and BeoLab 2 downstairs for the main living/dining room. With the BeoLab6000 being moved upstairs for the BeoVision. In listening to the BeoVision and knowing the 6000's sound i feel that i need to have a sub-woofer as part of the set up.
    I know that sound is a personnel thing, but what would the recommendation be between the BeoLab 2 or BeoLab 11
  • 01-31-2011 1:20 AM In reply to
    Re: BeoLab 2 or 11
    Some people complain about the Beolab2 being to slow and a little boom boom for their liking. The Beolab11 is good for the 6000. I have heard them with a beolab11 and they just sound great. I will be buying a beolab11 in the future to go with my 4000s.
    Beosystem 7000/6500- Beolab 4000 - Beosound 1 - A8 - Earset 3 - Beo4
  • 01-31-2011 5:14 AM In reply to
    Re: BeoLab 2 or 11
    jthorn:
    If this is to a bedroom and you are not using surround sound and lots of special effects etc then I would go to a BeoLab 11
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-31-2011 5:38 AM In reply to
    • jthorn
    • Not Ranked
    • Posts 3
    Re: BeoLab 2 or 11
    Should have said that upstairs is for a TV room
  • 01-31-2011 11:15 AM In reply to
    Re: BeoLab 2 or 11
    jthorn:
    so do you plan to go 5.1 surround sound eventually ?
    what sort of cinema experience do you want ?
    are you into big action movies ?
    which Beovision ?
    which BeoLabs ?
  • 02-01-2011 4:32 AM In reply to
    • jthorn
    • Not Ranked
    • Posts 3
    Re: BeoLab 2 or 11
    In response to your questions
    Would look at eventually going for a 5.1 surround sound. So will go from a BeoVision 10-46 and BeoLab 6000 to an eventual 5.1 system with the addition of a sub-woofer and another set of speakers
    In to all sorts of movies but probably 1 in 5 movies would be some big action movie
  • 02-08-2011 4:31 AM In reply to
    Re: BeoLab 2 or 11
    jthorn:
    I think you should work with your dealer and get a loan of a Beolab 11 and then a Beolab 2 (or vice versa)
    He stands to make a good profit from selling you an additional 3 speakers
    So he should be very willing to help you choose what is best for you
  • 02-08-2011 9:33 AM In reply to
    Re: BeoLab 2 or 11
    I was going for the BL11 but a BL2 in bad condition has just popped up on Yahoo Auciton Japan for half the price of the BL11 but isn't in good condition so I have been asking myself this question all day.
