Latest post 02-01-2011 3:04 AM by Mkicken. 5 replies.
Page 1 of 1 (6 items)
  • 01-30-2011 7:51 AM
    Audio over Beovision 1
    Perhaps you could help me with the following;
    I have a "BeoVision 1" and would like transfer the audio from a non-B & O source (Scart connected media player) and play the audio without the screen turned on. I know it possible with other B & O TVs via the "AV V.Aux" command on Beo4.
    Unfortunately this doesn't work with my Beovision 1, anyone has an idea whether and how this should work?
    Regards,
    Marcel
  • 01-30-2011 9:07 AM In reply to
    Re: Audio over Beovision 1
    Get in touch with Steve at sounds heavenly I am sure he can make a cable for you!  You may have to select A. Aux hope that helps Cheers Nick
  • 01-30-2011 10:28 AM In reply to
    Thanks for the reply.
    I tried with the "A.aux" option but it didn't work. I connected the player by scart, i don't have a masterlinl/powerlink connection on the tv (also not an option to build in). Seems to me it has to be connected by scart anyway.
    Regards,
    Marcel
  • 01-30-2011 3:45 PM In reply to
    what connections have you got on the set?
  • 01-30-2011 6:18 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Mkicken:
    Are you using a Beo 1 or a Beo 4 remote ?
  • 02-01-2011 3:04 AM In reply to
    I'm using a Beo4, the only connections are 2 x Scart, a "test" connection and a 'camcorder connection' at the front.
