Latest post 02-06-2011 7:50 AM by chuggsymalone. 4 replies.
Page 1 of 1 (5 items)
  • 01-30-2011 6:39 AM
    Beogram 5000 re-balancing...?
    I think I need to rebalance the turntable on my new / old Beogram 5000. I have played a brand new vinyl record which is perfectly flat, and it is clearly undulating on the turntable. Is it possible to rebalance it myself, and if so how do I do it?
    Many thanks!
  • 01-30-2011 7:09 AM In reply to
    Re: Beogram 5000 re-balancing...?
    Not quite sure what you mean. Do you mean the record does not seem flat on the platter? Or is the platter not flat compared to the deck? The first thing I would check is whether the record is sitting properly on the spindle. Sometimes the hole is not quite big enough and will not completely allow dropping so the record will appear warped. Usually there is just a small piece of label or vinyl that is preventing this.
  • 01-30-2011 7:31 AM In reply to
    Doctor:
    Second this, sometimes I have to enlarge the hole to get the Beogram 8002 to track it properly
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-30-2011 9:04 AM In reply to
    Søren Hammer:
    Doctor:
    Good advice. I have just checked the hole and the spindle, but the LP is sitting just fine. Here is a short video showing the problem. There is a small amount of camera shake, but the reflection on the vinyl tells it all.
  • 02-06-2011 7:50 AM In reply to
    Søren Hammer:
    Doctor:
    I have fixed the problem! One of the transport screws under the turntable had worked itself into (or about halfway into) the locked position. Now wobble and acoustic distortion has gone.
