Latest post 03-10-2011 4:12 AM by dug11. 12 replies.
Page 1 of 1 (13 items)
  • 01-29-2011 3:09 PM
    • dug11
    • Not Ranked
    • Joined on 03-10-2010
    • Posts 50
    • Silver Member
    Beomaster 5000
    Hi all
    i bought Beomaster 5000 with Master Control panel and i have question
    beomaster can be operated only with master control panel? that is what is with mine.
    i cant do nothing by buttons on beomaster.
    thanks
  • 01-29-2011 3:55 PM In reply to
    • geearr
    • Top 200 Contributor
    • Joined on 03-27-2008
    • Gold Coast, Australia
    • Posts 301
    • Gold Member
    Re: Beomaster 5000
    Hi dug11
    You may have a problem with the flexible ribbon connector which connects the front panel to the PCB.  This breaks very easily and is a fairly common issue with these machines.  Fortunately, it is not too hard to fix if you have some basic repair skills.  First research this site for several articles that cover this problem.  They may help you identify the solution to your specific problem.  If you need help with repairing the flexible connector, I can send you some step by step instructions.
    Regards
    Geoff
  • 01-29-2011 4:55 PM In reply to
    • dug11
    • Not Ranked
    • Posts 50
    • Silver Member
    Re: Beomaster 5000
    thanks for quick answer. i will be grateful if you send me step by step instruction
    i was looking in forum but didnt found similar problem solution
  • 01-29-2011 10:53 PM In reply to
    • geearr
    • Posts 301
    • Gold Member
    Re: Beomaster 5000
    Please send me a PM with your home email address and I will send you a large Word file with some instructions and photos.
    Regards
    Geoff
  • 01-30-2011 12:13 AM In reply to
    • mediabobny
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Beomaster 5000
    dug11:
    It can also be operated with a hand-held Terminal 5000 remote control.
  • 02-28-2011 9:42 PM In reply to
    Re: Beomaster 5000
    Geoff
    Could you send me the same instructions and photos if you still have them?  I'm having the same problem.  The front panel won't open without forcing it, and most of the buttons don't operate, but the remote works.
    Thanks,
    Kris
  • 03-01-2011 3:00 AM In reply to
    • geearr
    • Posts 301
    • Gold Member
    Re: Beomaster 5000
    Hi and welcome to Beoworld
    First, don't force the front panel unnecessarily.  If you have to open it and it won't respond to the push button, the best thing to do is remove the top cover and release the latch from the inside.  Then leave the control panel open until you have fixed your problem.
    I can email you 10Mb of files with the information that you want but I will have to send it to your private email address.  Pse PM or send me your email address so that I can send you the files.
    Regards
    Geoff
  • 03-01-2011 10:04 PM In reply to
    Re: Beomaster 5000
    Thanks Geoff!  I sent you an email with my address so you can send me the files.
    Kris
  • 03-09-2011 2:51 PM In reply to
    • dug11
    • Not Ranked
    • Posts 50
    • Silver Member
    Re: Beomaster 5000
    hi all
    another question about my beomaster is why always when i turn it on volume is set at 36?and it doesnt remember sound settings(bass&treble)
    i tried to store settings via master control panel but it doesnt work...
    any ideas?
    many thanks
  • 03-09-2011 3:04 PM In reply to
    Re: Beomaster 5000
    I seem to remember that you need to press store twice!
  • 03-10-2011 3:22 AM In reply to
    • dug11
    • Not Ranked
    • Posts 50
    • Silver Member
    Re: Beomaster 5000
    whem i press Store it shows letter P on display and when i press store again nothing happens.
  • 03-10-2011 3:30 AM In reply to
    Re: Beomaster 5000
    You need the manual - here is a snippet! It is available on site for silver and gold members.
  • 03-10-2011 4:12 AM In reply to
    • dug11
    • Not Ranked
    • Posts 50
    • Silver Member
    Re: Beomaster 5000
    done! many thanks for your help!
